if commands in linux
27 Sep 2022 04:25 #252828 by foam man
if commands in linux was created by foam man
i need to use the If function
heres what id like to do
#<code>= 6
#<flange>= #<code>
#<flangedp>= #<code>
if #<code>= to 6 then #<flange>= 2 and #<flangedp>=.25
  if #<code>= to 4 then #<flange>= 1.5 and #<flangedp>=.125
G1 x .5
G1 Y- #<flange>
i know this is not the correct way to write this, but i'm wondering if this scenario is even possible
27 Sep 2022 07:18 - 27 Sep 2022 07:22 #252832 by Aciera
Replied by Aciera on topic if commands in linux
Have you found the documentation regarding GCODE in LinuxCNC ? :
linuxcnc.org/docs/html/gcode/overview.html
Also sound like you may want to have a look at the O codes documentation:
linuxcnc.org/docs/html/gcode/o-code.html
You will find an example of conditional gcode in the above documentation (section 3)
Last edit: 27 Sep 2022 07:22 by Aciera. Reason: add link to o codes
27 Sep 2022 07:25 #252834 by mgm
Replied by mgm on topic if commands in linux
Aciera was faster ..... the example in the attachment I use for drilling for holes considering the length of a rail
File Name: auszuege2.ngc
File Size:4 KB
29 Sep 2022 04:01 #252987 by foam man
Replied by foam man on topic if commands in linux
thanks to both of you
your help is appreciated
so i wrote the following
Linux does not complain about it, but doesn't really run it either
the computer running the machine is pretty small and I'm wondering if that is the problem
Any ideas?
(#<TBcode>= 66) ( enter top&bottom code)
#<LRcode>= 46 ( enter left&right code)
#<Lflange>=1
#<Lflangedp>=1
#<Rflange>=1
#<Rflangedp>=1
o101 if [#<LRcode> EQ 66]
#<Lflange>= 1.5
#<Lflangedp>= .25
#<Rflange>=1.5
#<Rflangedp>=.25
o101 elseif [#<LRcode> EQ 64]
#<Lflange>= 1.5
#<Lflangedp>=.25
#<Rflange>=2
#<Rflangedp>=.5
o101 elseif [#<LRcode> EQ 46]
#<Lflange>= 2
#<Lflangedp>= .5
#<Rflange>=1.5
#<Rflangedp>=.25
o101 elseif [#<LRcode> EQ 00]
#<Lflange>= 0
#<Lflange> 0
#<Rflange>=0
#<Rflangedp>=0
G91
g1y 20
g1x- #<Rflange>
g1y #<Rflangedp>
g1x- 40
g1y- #<Lflangedp>
g1x- #<Lflange>
g1y- 20
g1x #<Lflange>
g1y- #<Lflangedp>
g1x 40
g1y #<Rflangedp>
g1x #<Rflange>
29 Sep 2022 06:54 #252996 by Aciera
Local parameters are only visible (ie usable) inside the subroutine, see section 3 - Scope:
linuxcnc.org/docs/html/gcode/overview.html#_named_parameters
Missing: o101 endif
G1 move requires a feedrate.
So here is a suggestion (You might want to move to a defined position before calling the subroutine ie before o100 call):
o100 sub
    #<Lflange>=1
    #<Lflangedp>=1
    #<Rflange>=1
    #<Rflangedp>=1
    #<LRcode>= 46( enter left&right code)
        #<Lflange>= 1.5
        #<Lflangedp>= .25
        #<Rflange>=1.5
        #<Rflangedp>=.25
        #<Lflange>= 1.5
        #<Lflangedp>=.25
        #<Rflange>=2
        #<Rflangedp>=.5
        #<Lflange>= 2
        #<Lflangedp>= .5
        #<Rflange>=1.5
        #<Rflangedp>=.25
        #<Lflange>= 0
        #<Lflange>= 0
        #<Rflange>=0
        #<Rflangedp>=0
    o101 endif
    g1 y20
    g1 x -#<Rflange>
    g1 y #<Rflangedp>
    g1 x-40
    g1 y -#<Lflangedp>
    g1 x -#<Lflange>
    g1 y-20
    g1 x #<Lflange>
    g1 y -#<Lflangedp>
    g1 x 40
    g1 y #<Rflangedp>
    g1 x #<Rflange>
o100 endsub
G91
F300
o100 call
M2
07 Oct 2022 02:21 #253642 by foam man
thanks guys it looks like it worked
I realized too late though that I can't use the I J or R command to make circles when in 4 axis mode XYZA
is it possible to do this?
Time to create page: 0.093 seconds
