Can you translate the program? If yes how
4 years 1 month ago #253209 by George777
Hello, i would like to translate the program to different language than english? If its possible how can someone do that?
I tried searchign in the docs but i did not found it..
4 years 4 weeks ago #253267 by andypugh
4 years 4 weeks ago - 4 years 4 weeks ago #253268 by andypugh
Actually, it looks like you can't add a new language on that page. Which language do you want to add? We probably have to create some support files.
Last edit: 4 years 4 weeks ago by andypugh.
4 years 4 weeks ago #253287 by JT
If you're asking how to translate the Axis interface for example it should translate when you change your locale.
JT
4 years 4 weeks ago #253317 by HansU
It is at least mentioned in the docs:
linuxcnc.org/docs/devel/html/code/contri...c.html#_translations
As fare as I know there is a more detailed section in work.
And it should be possible for you to add a language. At least I got emails that some users added languages.
But if not, I can add it for you.
And it is only possible for the 2.9 version, not for the current stable 2.8.
Time to create page: 0.348 seconds
