- LinuxCNC
- General LinuxCNC Questions
- Will it work: RPi4 8GB (64bit?) + MESA 7C81 RPI FPGA + MESA 7I76 + XHC WHB04B?
- palmhoej
03 Oct 2022 07:57 #253321
by palmhoej
Will it work: RPi4 8GB (64bit?) + MESA 7C81 RPI FPGA + MESA 7I76 + XHC WHB04B? was created by palmhoej
Hi LinuxCnc people, new to this community, but excited to try this setup for my second CNC Router, a QueenAnt from Yuyong (Beefed up QueenBee with linear rails and ballscrews).
I was gonna go with an old laptop and the Mesa 7I76e with ethernet, but chip shortage put an arrow through that idea, with 15 weeks of lead time (and maybe even more). So I found the MESA 7i76 used on ebay (and acted fast, maybe too fast), bought a new MESA 7C81 and a very expensive RPi4 8GB (In route as I type). And then the questions start to accumulate:
1. How do I connect the MESA 7C81 with the 7i76? Are they even compatible or did I make a mistake? If they are, what cable do I connect them with?
2. I was gonna try the 64bit on the RPi 8 gb, but could not find an image. Is the only way to compile from scratch?
3. I want a teach pendant like the XHC WHB04B-4. I can see from doc, that this is supported from linuxcnc. But can I expect that this will also work on the RPi? Any tips and tricks to get a teach pendant up and running on the pi as painless as possible is welcome (since I have not bought that one yet).
Background: Mechatronic engineer, 20 + Arduino and 5 RPi, second CNC build, old one was a 6040 with Mach3 and Smoothstepper.
- Thank you received: 4648
04 Oct 2022 01:10 #253401
Replied by andypugh on topic Will it work: RPi4 8GB (64bit?) + MESA 7C81 RPI FPGA + MESA 7I76 + XHC WHB04B?
Your 7i76 should plug straight in to the 26 pin headers on the 7C81 with the right firmware, no cause for concern there.
Try flashing the SD card image here:
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=130#238020
The XHC pendant should work, but I have never used one on a Pi or anything else, so can't say more than that.
The following user(s) said Thank You: palmhoej
- palmhoej
04 Oct 2022 06:49 #253417
by palmhoej
Replied by palmhoej on topic Will it work: RPi4 8GB (64bit?) + MESA 7C81 RPI FPGA + MESA 7I76 + XHC WHB04B?
Hi andypugh
Thank you for the quick reply, i have heard that this was a great community and so far you are proving it.
1. As far as I can see the 7I76 only comes with a printerport (and no 25 pin connector) and the 7C81 only has a 25pin connector (If that is what the long black once are called. So I guess i would need an adapter cable?
2. Thank you for that link, that was exactly what i was looking for
3. Well i might just take the plunge then, and order one. Then i can report on my findings.
Thank you for that link, that was exactly what I was looking for
04 Oct 2022 10:41 #253431
Mesa probably have one available for the purpose, though I would probably make my own by re-terminating a parallel port cable.
Note that Mesa only has the 7i76D in stock, which is the sinking output version (ie the output pins switch to GND when activated and open circuit when deactivated. (think NPN rather than PNP if that makes sense to you))
Yes. Something like cpc.farnell.com/startech/plate25f16lp/ca...dp/CS24156?ost=idc26 except that the 7i76 has a DB25F too, so really you need a 26 pin female header to DB25 _male_1. As far as I can see the 7I76 only comes with a printerport (and no 25 pin connector) and the 7C81 only has a 25pin connector (If that is what the long black once are called. So I guess i would need an adapter cable?
- LinuxCNC
Time to create page: 0.070 seconds
