Axis configuration
- eslavko
4 years 4 weeks ago #253430
by eslavko
Axis configuration was created by eslavko
Hello..
How to proper setup machine without Z axis?
Machine have X,Y and A/A2 (A is rotary and have two servos in parallel). Z axis is just pneumatic plunger (on/off).
In configuration dropdown of pnconf I got only XYZ, XYZA and XZ Lathe
- Yannis
- Thank you received: 4
4 years 3 weeks ago #253516
by Yannis
Replied by Yannis on topic Axis configuration
i m not an expert but maybe use z axis as spindle(on off)
in a gantry?(A,A2) configuration
- eslavko
4 years 3 weeks ago - 4 years 3 weeks ago #253646
by eslavko
Replied by eslavko on topic Axis configuration
I know how to do that in INI file. But I expect many pnconf editing so I prefer if that can be done in pnconf as I don't like to make edits in ini every time I start pnconf.
(the simplest I see is to make XYZ and then rename Z with A in ini.)
Last edit: 4 years 3 weeks ago by eslavko.
Time to create page: 3.469 seconds
