starting with stepconf and mesa 7I97
- Vorms
09 Oct 2022 23:53 #253833
by Vorms
starting with stepconf and mesa 7I97 was created by Vorms
Hello, I am a beginner !
I see the starting point is the software stepconf.
I start a new machine and I am asking for driver type.
I would like to use 7I97 card with -10/+10V drive.
What should I enter for drive type, step time and other field ?
Is that a good idea to start with stepconf for a 7I97 card ?
Best regards
Thierry Vorms
Best regards
Thierry Vorms
- Thank you received: 7462
10 Oct 2022 00:56 #253837
Replied by tommylight on topic starting with stepconf and mesa 7I97
Mesa 7i97 is a new controller board so there is no support for it yet in PncConf , but have a look here there might be a ready made config to get you going.
Using StepConf for Mesa boards is not a good idea, it is for parallel port configuration.
www.google.com/search?q=mesa+7i97+site%3...wAEB&sclient=gws-wiz
- Thank you received: 5308
10 Oct 2022 00:58 #253838
Replied by PCW on topic starting with stepconf and mesa 7I97
There is no current support for the 7I97 with pncconf
(pncconf is a configuration utility for Mesa cards stepconf is not for Mesa cards)
There are a couple of options:
1. mesact may have 7I97 support (not sure)
2. There is an example hal/ini file set for the 7I97 in the 7i97.zip support file
(basic7i97.zip contains the hal and ini files)
Time to create page: 0.101 seconds
