New traj planner
- An
- Thank you received: 3
14 Oct 2022 03:17 #254096
by An
New traj planner was created by An
Hi Linuxcnc, I have a question relating to the new traj planner that was recently-ish implemented. In the video (see thread below) showing the improvement I note that the config is 500ipm - 30in/sec^2 and the new t.p runs at 400ipm. Am i correct in assuming that the limit of 400 is coming about as a function of the acceleration limitation (so increasing from 30in/sec^2 could theoretically get us to 500)? If not could somebody please explain to me what causes this limit?
Ant
forum.linuxcnc.org/forum/10-advanced-con...stersprograms-wanted
Ant
- An
16 Oct 2022 05:15 #254204
by An
Replied by An on topic New traj planner
Hey everyone i thought I would add something to this in the hope of a kind expert sharing their knowledge. I’m currently using 2.54 and wondering if i should upgrade to mesa card to get the full benefit of the new traj planner? I use two parallel ports and gecko g540’s currently… lots of 3d tool paths with short segments. Thanks to anyone in advance for answering my perhaps poorly worded questions!
- Thank you received: 7462
16 Oct 2022 14:20 #254226
Replied by tommylight on topic New traj planner
I might be off but the new trajectory planner is in use since 2.7, with the option of using the old lookahead if needed.
My advice, get a used PC, install the 2.8.4 official release ISO and configure the new PC or just copy the config folder from the old one, there is a wizard that takes care of the conversion to new version of LinuxCNC, but it might fail if you have anything compiled or extra complicated.
That way you can just unplug and plug whatever PC you need.
- An
16 Oct 2022 19:53 #254254
by An
Thanks Tommy I will do as you suggest. Referring my other question about what limits the speed in the demonstration video for the updated traj planner to 400ipm - am I way off with thinking it’s the acceleration settings? I will try changing these when I have 2.84 up and running but keen to hear what others think all the same.
16 Oct 2022 21:17 #254262
Well i am sure i had one machine running at over 2000 IPM, once close to 3000 but it ripped the belts.
Where did you find that it is limited? thinking of it, that is bad info, most machines i deal with are set at 24000mm/minute so that is very close to 1000 ipm!
- An
16 Oct 2022 22:13 #254277
by An
In the video here
which compares the same spiral path with same config settings and shows the increased speed achievable with the new traj planner. I assume the increase is owing to the increase in look ahead allowing the tp to plan ahead and not have exact stops at the end of every segment. What I’m trying to figure out is what limited the speed to 400 ipm instead of achieving the 500ipm at which it was set. I.e is it that it can’t look far enough ahead to achieve the 500ipm on this spiral path or is it the acceleration setting or something else…
Ant
Ant
16 Oct 2022 23:10 #254293
Probably acceleration and the short paths where the speed can not be reached.
- Thank you received: 5308
16 Oct 2022 23:33 - 16 Oct 2022 23:35 #254294
Replied by PCW on topic New traj planner
Yes, if I try the arcspiral with my test setup (200 IPS/S accel, 20 IPS velocity)
It starts out at about 1200 IPM and gradually slows as the spiral radius decreases
due to being acceleration bounded.
Note that that spiral is only about 4" across so 1200 IPM is a bit crazy
Last edit: 16 Oct 2022 23:35 by PCW.
- An
17 Oct 2022 03:50 #254304
by An
Ok great thanks for the help guys.
Time to create page: 0.373 seconds
