So I guess the support wasn’t that good, luckily I haven’t bought any Mesa equipment.But
They both provide the best tech support on earth, right here on thins forum!
So I sent you a couple of questions, because I'm a noob when it comes to CNC and RPI4b/Mesa cards, but I like the idea of making a setup with a small footprint. This is what I asked when I contacted Mesaus:
Hello
I’m looking at setting up a Raspberry pi 4b with 3-axis LinuxCNC and a Mesa card, but there are so many cards to choose from so I get confused, haha.
I would like a compact setup so I’ve been looking at your 7c80/7c81 card, but I guess I would need another breakout card for my stepper drivers(DM556 or similar) and for my peri pals like bit-setter, touch probe and end stops. I may also use a G540 driver card if it’s very much more easy to set up, but it will be much more costly so I would prefer to start with 3 separate drivers.
Thank you very much, much appreciated. A 4x4 size would be perfect for me.
Just a quick question, would the combined setup of 7c81 and 7i76 be more responsive towards working with the rpi4 than using the bigger 7i76e as I understand is a all in one card that connects to the ripi via Ethernet?
Terje
