motors not spinning during configuration test
20 Oct 2022 15:01 #254603 by xlordofpainx
motors not spinning during configuration test was created by xlordofpainx
I followed a basic tutorial on making the configuration file PNc conf and set up the motors. I have a nema32 with feedback hooked up to a
HBS86H2-phaseHybridServoDrive:  www.dropbox.com/sh/a3g4dw71q4taxsd/AACBv..._Data_Sheet.pdf?dl=0
I checked the phase wires, and encoder wires going to the driver, I checked signal control wires from the Mesa 7i96s to the driver and when I press the test option before finishing the config file, the motor does not spin. (the network configuration works fine and I can ping it). What would be a good place to start debugging?
  • Moderator
  • Moderator
20 Oct 2022 15:09 #254608 by tommylight
Replied by tommylight on topic motors not spinning during configuration test
Please stop starting new topics with the same questions, it is very hard to keep track what has been answered.
Answered on the other topic.
Thank you.
Time to create page: 0.075 seconds
