ERR: can't do that (EMC_TASK_PLAN_RUN) in auto mode with the interpreter reading
  • Waldemar
  • Waldemar's Avatar Topic Author
  • Senior Member
  • Senior Member
20 Oct 2022 23:23 #254636 by Waldemar
Good evening,
I've been using LinuxCNC 2.8.4 with my new control box for several weeks now, been running well and no issues so far.
Had a weird error pop up earlier - never had it before:
The PC was idling (after having run a simple cutting file around 20 times in a row) and had gone to a blank screen (I've disabled the need to log-on again every time this happens).  When I went back to the PC I noticed that the error had popped up - I assume that it happened during the idle, as I'd have probably noticed it otherwise.
It didn't seem to affect anything, just bizarre to get it pop up out of nowhere...  Anything I should check / be aware of..?
Wal.
21 Oct 2022 12:25 #254668 by andypugh
It seems to be saying that it got a run command while already running.
Did you tap the screen to wake up the display? Is it possible that you tapped where the cycle-start button was about to appear?
  • Moderator
  • Moderator
21 Oct 2022 13:10 #254679 by tommylight
Pretty sure i saw that once or twice, never bothered with it as i thought i dumped pliers or screwdriver on the mouse or keyboard.
Will keep an eye on it.
Only on a PC with a touchscreen, so might also be induction from other equipment, i use plasma cutters a lot, thouchscreens do not like plasma, at all! :)
Time to create page: 0.082 seconds
