- Thank you received: 37
Keyboard and Mouse become unresponsive in AXIS.
- clunc
- Topic Author
4 years 1 week ago - 4 years 1 week ago #254814
by clunc
Keyboard and Mouse become unresponsive in AXIS. was created by clunc
I mentioned this
before.
LinuxCNC (2.8, AXIS, Ubuntu 20.04, Intel Duo core with isolcpus=1, Mesa 6i25, open-loop stepper system) is executing a program.
To amuse myself while it's running, I'm zooming, rotating, dragging, etc. the model in the AXIS window when--just like that--AXIS stops responding to mouse AND keyboard inputs. It doesn't seem to be a buffer issue that recovers later. They never seem to come back.
Meanwhile LxCNC continues running the program just fine.
The most troublesome thing about this is that F1, F2 and Esc are all ignored: no E-stop from the keyboard.
If AXIS is full-screen, I can't minimize it to get to anything else. (I didn't think to try Ctrl-T to open a new terminal.)
I finally opened a new (what's it called: "terminal") with Ctrl-Alt-F5 [so THOSE keys were honored] and logged in and ps'd and killed every linuxcnc routine I could find. When I went back to the original terminal and restarted LinuxCNC, keyboard and mouse worked fine.
Has this been seen before?
Is there a recovery procedure?
I'd hate to have to kill and restart over this.
You Linux gurus, could I do something like restart the workspace manager, display manager or desktop, or something like that? (I don't even know what I'm saying...)
Thanks.
Thanks.
Last edit: 4 years 1 week ago by clunc.
4 years 1 week ago #254815
Replied by tommylight on topic Keyboard and Mouse become unresponsive in AXIS.
Sorry for the short reply,
if discrete graphic card = change the graphic card
if built in graphic card, change the memory, or test one by one and remove the one that locks the GUI.
I am sure it is something to do with Open GL, but it is almost always graphic card related, and almost always failing memory.
Built in or integrated graphics use the system memory.
- snowgoer540
- Thank you received: 907
4 years 1 week ago #254861
by snowgoer540
"E-stop" (I hesitate to even call it that) from the keyboard should never take the place of a proper physical, hardware E-stop.
Esc is convenient as a non-emergency "Abort" or "Cycle Stop". But again, should never be relied on to stop the machine in an actual emergency.
Replied by snowgoer540 on topic Keyboard and Mouse become unresponsive in AXIS.
- clunc
- Topic Author
4 years 1 week ago #254870
by clunc
Replied by clunc on topic Keyboard and Mouse become unresponsive in AXIS.
:thumbsup:
Thank you. BOTH graphics card AND memory sticks are questionable in this old Dell 780.
As it was, I ran the million-or-so lines of G-code and didn't amuse myself by fussing with views, and it came out fine, if a little off-center, but I think that one's on me.
4 years 1 week ago #254895
Replied by andypugh on topic Keyboard and Mouse become unresponsive in AXIS.
I get the reported problem if I leave my little wireless keyboard dongle plugged in. (I use the touchscreen nearly all the time, the little keyboard only comes out of its holster for g-code changes at the machine)
Looking at dmesg it tends to flood the log with connect/disconnect messages.
So, if you have a wireless KB or mouse I would suspect them.
Time to create page: 0.066 seconds
