linux cnc 7I97 version pnconf
- Vorms
24 Oct 2022 18:27 #254935
by Vorms
linux cnc 7I97 version pnconf was created by Vorms
Hello,
I installed linux cnc 2.8
I have a 7i97 mesa card.
pnconf didn't support 7i97 or I do some mistake.
Is there a way to update pnconf or is it needed to update linuxcnc to 2.9?
what is the right way to go to 2.9 (if it is needed) ?
Many thanks for your help
- Thank you received: 4648
24 Oct 2022 18:35 #254937
Replied by andypugh on topic linux cnc 7I97 version pnconf
2.8.4 has driver support for the 7i97 but the config tools may nt know how to set it up.
Maybe set up a 7i77 and change the device name in the INI. That should be fairly close.
Also change "loadrt hm2_pci" to "loadrt hm2_eth board_ip=10.10.10.10 (or whatever) in the HAL file too.
- Thank you received: 5308
24 Oct 2022 18:40 #254940
Replied by PCW on topic linux cnc 7I97 version pnconf
In the 7I97.zip support file, there is a 7I97 sample hal/ini file set
(basic7i97) that is probably the best starting point for a 7I97 configuration
- Vorms
24 Oct 2022 19:41 #254947
by Vorms
Replied by Vorms on topic linux cnc 7I97 version pnconf
Ok thank you for your response
Regards
Regards
Time to create page: 0.224 seconds
