Float switch code
- rajsekhar
- Thank you received: 12
25 Oct 2022 05:57 #254996
by rajsekhar
Float switch code was created by rajsekhar
Hello friends, I am trying to build a oxyfuel cutting machine.
Now, unlike plasma machines using PlasmaC, I am trying to use sheetcam generated codes that gives complete custom control of Z axis. Also I have deceided using capacitive THC using thc components if linuxcnc.
But I am stuck with float switch. I will use 200mm range contact optical digital output sensor so that nozzle do not touch plates.
but how to enable that with sofware? what code i should use in Gcode file?
- Thank you received: 4150
25 Oct 2022 08:16 #255000
Replied by rodw on topic Float switch code
Ypu can try a gcode approach using a touchoff.ngc file similar to this on from JT
gnipsel.com/shop/plasma/files/touchoff.ngc
- Thank you received: 7488
25 Oct 2022 09:11 #255006
Replied by tommylight on topic Float switch code
Wha signal does the capacive sensor output?
- rajsekhar
25 Oct 2022 09:27 #255008
by rajsekhar
Replied by rajsekhar on topic Float switch code
It is a digital output , NO+NC available.
25 Oct 2022 09:37 #255010
Strange, should be analog.
How do you set the sense height? With a pot on it?
Does it have two separate outputs, one for over and the other for under the limit?
- rajsekhar
25 Oct 2022 09:38 #255011
by rajsekhar
I mean float switch is digital output. Capacitive THC gives analog voltage output.
25 Oct 2022 09:40 #255012
Is the voltage range usable with a THCAD?
So 5 to 10V? Or more ?
- rajsekhar
25 Oct 2022 10:06 #255013
by rajsekhar
That I am not sure right now.
If it is beyond THCAD range i have plan to use voltage divider. I have THCAD 5 in my stock.
Will update as soon as i get the values.
- rajsekhar
25 Oct 2022 10:51 #255015
by rajsekhar
I have never used subroutine before.
Request for practical guide how to use that.
subroutine in gcode file or a separate file??
26 Oct 2022 05:00 #255078
The intent was the touchoff was called in our gcode when the cutting should start. You normally pass it some variables. Time to read up on gcode subroutines.
Time to create page: 4.318 seconds
