O code use
25 Oct 2022 14:06 #255035 by rajsekhar
O code use was created by rajsekhar
I am new with I o-code and require to use it for the first time.
but not sure how to use. Where should the o code be written, in gcode file or some where else?
  • Moderator
  • Moderator
25 Oct 2022 14:11 #255036 by tommylight
Replied by tommylight on topic O code use
25 Oct 2022 15:52 #255041 by rajsekhar
Replied by rajsekhar on topic O code use
Well, I tried and it is a sucess.
Just for novice like me, O-code shall be written at the start of program and then shall be called where required. Also M2 code is not mandatory after o-code is called, at least I did not use the M-code.
Time to create page: 0.344 seconds
