Ballscrew articulation, has anybody had success?
- coaster
26 Oct 2022 11:00 #255088
by coaster
Ballscrew articulation, has anybody had success? was created by coaster
Has anybody replicated a 'port block' style of milling machine?
- Thank you received: 7485
26 Oct 2022 14:34 #255101
Replied by tommylight on topic Ballscrew articulation, has anybody had success?
More info?
- cakeslob
- Thank you received: 280
27 Oct 2022 03:18 #255161
by cakeslob
Replied by cakeslob on topic Ballscrew articulation, has anybody had success?
Didnt think they used this on cnc machines, but I guess you can get a whole 120 degrees outta it so not bad. I figured control would be something linear like (ballscrew travel/total degrees)/steps per mm
tommy, it looks like centroid has a 5 axis mill that uses linear ballscrews for rotary motion, like those fancy laser adjustment stages.
Thats if I understand it correctly. I havent seen any diy implementations before but my interest is piqued now.
- zack
- Thank you received: 47
27 Oct 2022 07:35 #255169
by zack
Replied by zack on topic Ballscrew articulation, has anybody had success?
The following user(s) said Thank You: tommylight, Stanislavz
27 Oct 2022 10:26 #255173
Ok, that explains a lot.
A balscrew and some good bearings can get pretty good tolerances compared to cheap gearboxes, so that might be one of the reasons for using this.
27 Oct 2022 21:44 #255249
Replied by andypugh on topic Ballscrew articulation, has anybody had success?
It would need some maths in the kinematics file to convert linear motion to the final angle, but it seems simple enough.
I think this is cooler:
- coaster
28 Oct 2022 23:34 #255357
by coaster
Replied by coaster on topic Ballscrew articulation, has anybody had success?
I have designed a few iterations, 8 degrees plus and minus (16 total) can be done with just ballscrew mapping on Mach3 using an 80mm water cooled spindle held in a pillow ball.
Bigger ambitions require more forethought.
28 Oct 2022 23:39 #255358
That's a good point, ballscrew mapping would probably work for LinuxCNC too.
- Gautham
- Thank you received: 3
16 Jan 2025 09:37 #319104
by Gautham
Replied by Gautham on topic Ballscrew articulation, has anybody had success?
Hi
I am new to CNC and specifically LInuxCNC. I am trying to build something like this for my B axis except I use the ball screw to turn the spindle rather than turning the workpiece. So it is possible to write a math function to relate the linear motion to the angle of the axis. It is similar to the formula used to find the crankshaft angle when the piston has travelled x distance. Like this
But how do I enter this into LinuxCNC? I am ok with the math I need help on the implementation into LinuxCNC
- User_paulvdh_42
18 Jan 2025 12:29 #319274
by User_paulvdh_42
Replied by User_paulvdh_42 on topic Ballscrew articulation, has anybody had success?
Normally you get better answers on a forum if you show you've put in some effort yourself, and then ask more specific questions.
You can start by reading about Kinematics in LinuxCNC
linuxcnc.org/docs/2.8/html/motion/kinematics.html
In short: You write your custom kinematics in C, and "halcompile" compiles it into something compatible with LinuxCNC.
Time to create page: 0.174 seconds
