Problem Installing Probe Screen
- SertanATL
29 Oct 2022 12:20 #255371
by SertanATL
Problem Installing Probe Screen was created by SertanATL
I am using Debian 11 with Linuxcnc installed from this link (github.com/joco-nz/lcnc-bullseye-installer)
I have Mesa 7i76e and succesfully wired a probe for measuring tool length. Unfortunately I could not install a probe screen like this one (github.com/linuxcnc-probe-screen/probe-screen-ng) or run a MDI command to automatically probe. A simple solution would be great!
- Thank you received: 4648
30 Oct 2022 21:53 #255495
Replied by andypugh on topic Problem Installing Probe Screen
Which version of LinuxCNC do you have from that install method?
LinuxCNC 2.9 has moved to Python3 and GTK+3 and I suspect that that probe screen has not.
Alternatively the issue might be the glade version, try "sudo a-t-get install glade-gtks"
- SertanATL
31 Oct 2022 07:00 #255548
by SertanATL
Replied by SertanATL on topic Problem Installing Probe Screen
It is 2.9.0-pre. I understand the problem now... Thanks!
