Issues with setting up 3 axis mill
3 years 11 months ago - 3 years 11 months ago #256047 by cadpete
I am building a 3 axis vertical mill and have spent more than a month trying to get the motors to run.iI am using raspberry pi 4 and MESA 7i76En  step generator with 3 CL57T (v4) stepper controllers (closed loop)..
X and Y axis both work fine in pncconfig but I always get encoder fault on the CL57T for Z tests as soon as I try to move it.
So far I have tried -swapping motor positions - always Z died so not motor.
swapping controller positions - always Z dies so not contrroller.
Swapping encoder leads - always z drive died so not leads swapping MESA stepper leads - always Z died
swapping order of mesa connections - always Z died
I have noticed that often on moving X or Y the Z motor will make a noise, without movement.
Anyone have any additional ideas to test?
Last edit: 3 years 11 months ago by cadpete. Reason: clean up format added one extra test made
3 years 11 months ago #256057 by chris@cnc
where is your motor wired?
X-Axis is stepgen.00
Y-Axis is stepgen.01
Z-Axis is stepgen.03
What is on stepgen.02?
3 years 11 months ago #256062 by cadpete
Was on Stepgen 2 but was trying 3 to eliminate that as an option
3 years 11 months ago - 3 years 11 months ago #256064 by chris@cnc
i mean on your mesa 7i76e card. Stepgen 3 is the top socket on TB2
your issue sound like a wiring problem
Last edit: 3 years 11 months ago by chris@cnc.
3 years 11 months ago #256065 by cadpete
I understand. I was using Stepgen 02, but on the files sent I had tried using Stepgen 03 to eliminate the Mesa card Stepgen 02 from the error chain in case it had been damaged in the previous attempts
3 years 11 months ago #256069 by PCW
Are you having this problem with LinuxCNC or pncconf?
The noise from Z when you move X,Y really sounds like a wiring issue
Suggestions:
Test with LinuxCNC, not pncconf
Change this hal line:
set setp hm2_7i76e.0.dpll.01.timer-us -50
to
setp hm2_7i76e.0.dpll.01.timer-us -200
Check the Z wiring
Change the step/dir wiring to single ended:
Drive DIR+ and PUL+ to 7I76E +5V
Drive DIR- and PUL- to 7I76E DIR- and PUL-
Time to create page: 0.082 seconds
