Axis Display with reduced information
- Wusel
- Thank you received: 8
07 Nov 2022 21:58 #256166
by Wusel
Axis Display with reduced information was created by Wusel
With my latest project, a Luxturn converted to LinuxCNC now almost completed, I would like to reduce the information on the display. I am using the axis display in lathe configuration. Since I only program in Diameter mode I want to eliminate the radius . Moreover I am not interested in the distance to go dtg numbers neither in the A-Axis angle since the a-axia is the tool changer. So all I want to have left on the display is X, Z.
How would I do this?
- Thank you received: 7462
07 Nov 2022 23:04 #256172
Replied by tommylight on topic Axis Display with reduced information
A lot of stuff can be enabled and disabled from the view menu, did you try that?
- Wusel
07 Nov 2022 23:43 #256174
by Wusel
Replied by Wusel on topic Axis Display with reduced information
no, I hadn't come across teh view menu. Stupid question but where would i find it?
Rainer
Rainer
07 Nov 2022 23:48 #256175
AXIS GUI,
file, machine, view, help <<< those are drop down menus.
Top left corner, not sure about the order though.
- Wusel
09 Nov 2022 17:59 #256299
by Wusel
thanks, I managed to take at least a few information off the screen. The radius and A-axis display remain as unwanted information but it is already much cleaner than before
09 Nov 2022 19:38 #256304
What type of tool changer?
I have the changer with it's own component so no axis shown.
Radius and perimiter i would leave, it is a nice reminder not to mess up!
- Wusel
10 Nov 2022 07:51 #256324
by Wusel
it is a 8 station revolver which I set up as A-axis. Since all axis are displayed the rotational angle of the revolver ist shown too. With components I've not worked yet,
10 Nov 2022 09:12 #256330
When you feel like taking on a chalenge, give the carousel component a try, it is made by Andy for all kinds of tool changers.
- Wusel
10 Nov 2022 11:08 #256343
by Wusel
ok, I'll give that a try once I mastered the tuning of the lathe spindel and afterwards unfortunately the complete new control of my Imes Wieland mill
