linuxcnc cmake project
- Grotius
- Thank you received: 2349
01 Nov 2023 09:43 #284245
by Grotius
Replied by Grotius on topic linuxcnc cmake project
Thanks for reporting this starting problem.
In the build script at line 62, enable the sudo make setuid lines.
Or in the ~linuxcnc/src directory : $ sudo make setuid
The following user(s) said Thank You: tivoi
- tivoi
- Thank you received: 20
01 Nov 2023 13:50 #284256
by tivoi
Replied by tivoi on topic linuxcnc cmake project
cnc@debian:~/linuxcnc/cmake$ cd ..
cnc@debian:~/linuxcnc$ cd src
cnc@debian:~/linuxcnc/src$ sudo make setuid
chown root ../bin/rtapi_app
chmod 4750 ../bin/rtapi_app
chown root ../bin/linuxcnc_module_helper
chown: cannot access '../bin/linuxcnc_module_helper': No such file or directory
make: *** [Makefile:602: setuid] Error 1
still err
still err
- Grotius
02 Nov 2023 15:05 #284335
by Grotius
Are you able to clone a new one again? Then run the build_all again.
I made some changes to the source code & install process. At my place this went well :
$ git clone github.com/grotius-cnc/linuxcnc.git linuxcnc-test
$ cd linuxcnc-test
$ cd cmake
$ ./build_all
$ cd linuxcnc-test
$ cd cmake
$ ./build_all
- Rickstar73
20 Jul 2025 22:49 #332087
by Rickstar73
Replied by Rickstar73 on topic linuxcnc cmake project
How are you?
How are you progressing with this, did you get it to install successfully?
How are you?
Time to create page: 0.097 seconds
