Cant run Sample Configurations
17 Nov 2022 15:21 - 18 Nov 2022 11:34 #256935 by holziCNC
Cant run Sample Configurations was created by holziCNC
Hello everyone,i have installed linuxCNC for the first time to try it out.To begin i wanted to use one of the sample configs with simulation to find an easy introduction to linuxCNC. But when i run any sample config i get the following error message.is this a known problem?is there a solution?
Last edit: 18 Nov 2022 11:34 by holziCNC.
  • Moderator
  • Moderator
17 Nov 2022 19:11 #256947 by tommylight
Replied by tommylight on topic Cant run Sample Configurations
Something wrong with the attachment, please upload the pictures here on the forum, there is a button "attachments" under the editor.
18 Nov 2022 00:02 #256992 by andypugh
Replied by andypugh on topic Cant run Sample Configurations
Might be one of these: www.google.com/search?q=IMG_2024.JPG&tbm=isch
But I suspect not. :-)
18 Nov 2022 11:35 #257028 by holziCNC
Replied by holziCNC on topic Cant run Sample Configurations
Sorry now there should be a picture
18 Nov 2022 13:18 #257032 by andypugh
Did you build LinuxCNC from source?
If so, then I suspect that you forgot the "sudo make setuid" step.,
If not, then it's a more perplexing question.
18 Nov 2022 13:20 #257033 by andypugh
Looking more carefully, you are logged in as root.
Some info here, and the same problem.
www.forum.linuxcnc.org/49-basic-configur...4-and-7i76e?start=10
  • Moderator
  • Moderator
18 Nov 2022 13:23 - 18 Nov 2022 13:27 #257034 by tommylight
Reinstall is the only option, and this time when asked for a ROOT password, just click next. But do add a USER password.
A lot of software will refuse and/or complain when run as ROOT, it is a full rights administrator account.
Edit:
Please notice on the picture, Linux is running with the ROOT user account.
Last edit: 18 Nov 2022 13:27 by tommylight. Reason: more info
18 Nov 2022 23:16 #257076 by andypugh
I am a bit confused, because the LinuxCNC installer doesn't offer the option to create a root password (it is pre-seeded as blank)
  • Moderator
  • Moderator
19 Nov 2022 03:02 #257090 by tommylight
I am sure of that, i have 2.8.4 official ISO on one of the laptops.
Also i am sure he is running as ROOT, but i have no idea how or why.
19 Nov 2022 19:54 #257119 by rodw
Replied by rodw on topic Cant run Sample Configurations
You should not need to reinstall, just add a normal user if none exits, logout as root and login using that username and pw
Time to create page: 0.292 seconds
