Input voltage tolerance of Mesa 7i96S
- dashy81
- Thank you received: 3
19 Nov 2022 13:01 #257106
by dashy81
Input voltage tolerance of Mesa 7i96S was created by dashy81
Hey guys,
I'm using Mesa 7i96S with linuxcnc. To power this board I am using a stepdown buck converter module.
24V power supply->buck converter->Mesa 5V input
But before connecting to Mesa I tried checking the voltage of buck converter by connecting a multimeter.
On 24V smps getting switched off, I see buck converted output varies drastically from peaking upto 16-18v for then dying down.
As per my understanding Mesa can not tolerate this high voltage ? Is there any protection on Mesa 7i96S for overvoltage ?
Pls help.
Cheers
Pls help.
Cheers
- Thank you received: 5308
19 Nov 2022 14:41 #257109
Replied by PCW on topic Input voltage tolerance of Mesa 7i96S
The 7I96S has a overvoltage clamp diode but a large input surge that
is not current limited may overheat and damage this diode.
You might check you power supply with a small load, say 100 Ohms
and see if it still has an output overshoot.
- dashy81
19 Nov 2022 15:17 #257111
by dashy81
Replied by dashy81 on topic Input voltage tolerance of Mesa 7i96S
sorry... It was my fault.... the reported voltages were in millivolts.... so not an issue.... buck converter is behaving sanely... Thanks
Time to create page: 0.092 seconds
