LinuxCNC Mesa card and network
- Vorms
- Topic Author
3 years 11 months ago #257220
by Vorms
LinuxCNC Mesa card and network was created by Vorms
Hello, When linuxcnc run (with a mesa card) it is not possible to use the network.
As I see on forum I installed network-manager but this doesn't solve the problem.
When I run linuxcnc, I am unable to ping the local router...
How can I solve this issue ?
Many thanks for your help.
Best regards
Best regards
3 years 11 months ago #257224
Replied by tommylight on topic LinuxCNC Mesa card and network
Does it have 1 or 2 network cards?
With one, you can not use Mesa and Internet.
With 2, you can use both at the same time.
Since you gave no info, i can not offer more help for now.
P.S.
1 ethernet RJ45 and 1 wireless/WiFi also can be used at the same time with network manager, not with WiCD.
P.S.
- Vorms
- Topic Author
3 years 11 months ago #257233
by Vorms
Replied by Vorms on topic LinuxCNC Mesa card and network
Many thanks for your reply. The machine has only one ethernet interface. I am very surprised that it can not be possible to use the ethernet when linux cnc is running.
How can I load the gcode file in the Linuxcnc application? Is that some alternative? I see on a forum that installing network manager solve the issue, but not for me...
3 years 11 months ago #257234
Does it have WiFi?
- Vorms
- Topic Author
3 years 11 months ago #257237
by Vorms
No wifi....
I don't understand why the ethernet connection is 'blocked' when linux cnc run. Is that a linuxcnc design? Is it a possible to load a file from the network?
3 years 11 months ago #257238
Use a USB drive
Or USB WiFi
Or USB network card
Or USB WiFi
Or USB network card
- Vorms
- Topic Author
3 years 11 months ago #257242
by Vorms
If I modify the machine and will have two Ethernet Interfaces, can I connect both Ethernet interfaces in the same switch ? ie one for the mesa card and one for local network ?
3 years 11 months ago #257251
Replied by rodw on topic LinuxCNC Mesa card and network
The Mesa card requires a dedicated point to point ethernet connection so the real time performance is not affected by network latency. Its not a generic network device to install on your network. To also connect to the internet you must use a seperate NIC or wifi connection.
The documentation for th hm2_eth driver tell syou how to set a fixed IP addres for the NIC on the PC. Asssuming the ip Address of the mesa card is 10.10.10.10, use 10.10.10.1 at the PC end.
linuxcnc.org/docs/devel/html/man/man9/hm2_eth.9.html
- Vorms
- Topic Author
3 years 11 months ago #257263
by Vorms
Ok it's very clear now !
So If I add an interface, I will be able to load a file from a file server using the second interface.
Best regards
Thierry Vorms
Best regards
Thierry Vorms
3 years 11 months ago #257264
Yes.So If I add an interface, I will be able to load a file from a file server using the second interface.
Time to create page: 0.279 seconds
