- Thank you received: 2142
the gcode g2-g3 format problem.
- Grotius
- Topic Author
Currently working to use a interpreter like sai for 3d gcode.
In general i alway's end up with the same problem. Let your thoughts shine over this.
For example a g2 (cw) or g3 (ccw) arc, defined as usual :
- startpoint : {0,0,0}
- centerpoint : {50,0,0} (retrieved by i,j,k values)
- endpoint : {100,0,0}
The above coordinates are colinair, this is in fact a math problem where the 3d plane cannot be calculated or defined.
The plane can be anywhere between 2*M_PI,
But that is strange, because it's a arc. So the gcode misses some data here.
For xyz gantry low level application's nobody cares about planes etc.Personally i think it's better to define a arc in gcode format as follows :
- waypoint : {50,50,0}
It's also that the arc calculation becomes 3d, instead of 2d using vector formula's, wich are quite compact and easy to handle :
github.com/grotius-cnc/arc_points_3d/blob/main/arcpoints.cpp
In the end, what is the best way to go?
I think the arc with waypoint describes it all. On top off that the gcode abc can be used to drive the euler angles if the machine
is a robot etc.
- spumco
- Thank you received: 817
How does defining the start, waypoint, and end define the radius (or curvature?) of the 3D arc? Is it because the G2-ish (not G2 nor G3) is always an arc with those three point tangent to the arc?
So a 3D arc could be defined by:
G2-ish X0Y0Z0, X1Y0.5Z0.5, X2Y0Z0 Fnnn
Yes? (forgive me if the values are off, but trying to plot a 3D arc in my head is fussy)
So how is a parabola defined?
Next thing I'm thinking is I don't want to pay for another post-processor!image missing /media/kunena/emoticons/wink.png
- Grotius
- Topic Author
Yes, this is ok to define a 3d arc :
en.wikipedia.org/wiki/Parabola
image missing https://upload.wikimedia.org/wikipedia/commons/thumb/0/01/Parabel_2.svg/220px-Parabel_2.svg.png
Then Point F & A are important. You need the power of the parabola curve, like : y = x2.
If you got one extra reference point like B,C,D or E, (prefferred D) that's enough to define a 3d parabola.
Yes, i understand.
Below is a example of a 3d arc, that is a problem for cnc programs.
My personal opinion is that such arc moves should be possible for a cnc program. Robot controllers
are used to interprete such moves.
The current way is that the cam program will create a linestrip, so it loses it's arc format anyway.
A mdi move is currently only possible if kinematic component will rotate the workplane first.
example :
https://github.com/grotius-cnc/dump/blob/main/screen.jpg?raw=true
- spumco
This seems rather clever as the direction doesn't need to be defined with G2/G3, right? Just one G command and the waypoint ensures the direction is always correct.
And this system would have worked years ago when controls weren't capable of 3-axis coordinated moves. Wonder why the originators of G-code went with IJK (or R) instead of waypoints?
Trying to think if this scheme has complications related to cutter comp or lathe tool path generation (tip tangency). Need more coffee.
- Grotius
- Topic Author
This is a old video doing such moves, with euler's poses on top :
user-images.githubusercontent.com/448801...814-1199550dd265.mp4
I don't know. For standard xyz, you don't need it.
You can offcourse expand the gcode language, but then the question is, will it be adapted or accepted by others.
I think when creating a gcode interpreter, the gcode interpreter can just read the new GXX code that defines the 3d arc.
Yes, for me the best way of defining a 2d or 3d arc is using a waypoint. It's failsafe and no data get's lost, like the arc plane.
- Thank you received: 2620
There has been some work done on more flexible arcs, a long, long time ago. Take a look at the "arbitrary-arc" branch.
With a start point (current position) end-point (XYZ) and centre (IJK) the plane of the arc is well determined, but the direction is not, as it is ambiguous which direction the plane normal points. (There may be a standard for this?)
- Grotius
- Topic Author
This is true, but ... so far i know lcnc uses it to create spirals instead of describing 3d arc's.
For g2,g3, the startpoint z=0, the K=1, the endpoint z=2. Seen from top plane will create a spiral.
Correct me if i am wrong.
I don't know if there is a standard for this. If you know the normal axis, it's ok.
Yes, and it would be a bad idea to break this behaviour as spirals are probably more useful than out-of-plane arcs. (thread milling, for example)
I think that the answer would be to add G2.1 and G3.1 for arbitrary arcs.
(An alternative would be to decide that any arc with all three of IJK is an arbitrary arc, but I think that might be accidentally triggered by some CAM programmes)
I _think_ that if you include a K in the XY (g17) plane that you get an error message.
Three points define a plane, but the plane normal can point in either of two directions.
There is a nice interactive thing here: mathinsight.org/forming_planes#:~:text=I...ou%20are,x%E2%88%92a )%3D0.
Which defines the plane normal as the cross product of the vectors from one point to two others. But I think that if you change the base point you flip the normal.
But we could just decide that the plane normal is Centre-Start × Centre-End. Which is mathematically unambiguous but might end up with a lot of holding hands in odd positions and trying to remember which digit is which axis.
en.wikipedia.org/wiki/Right-hand_rule (order matters A × B != B × A
SVG settles this ambiguity with two flags, sweep and large: developer.mozilla.org/en-US/docs/Web/SVG/Tutorial/Paths#arcs
- Grotius
- Topic Author
G2.1 & G3.1 sounds ok to me.
Yes, but that's no problem to define a 3d arc.
If you have arc start, way & endpoint, you can calculate the centerpoint,
and the center axis (neutral). Arc angle is then calculated, this needs a tiny if-else if output angle is negative. (not signed).
The opencascade lib has also 3d arc's, but they are computed quite complex.
This recent code solves a 3 point 3d arc, output is tested ok in opencascade :
