how to start an .ngc file somewhere in the middle?
- Wusel
- Thank you received: 8
01 Dec 2022 18:02 #258238
by Wusel
how to start an .ngc file somewhere in the middle? was created by Wusel
dear all,
here comes a simple question regarding the use of Linuxcnc:
I want to run an ngc file not from the start but from somewhere further down the line. If i select the line and press the start button it jumps back to the top and starts from there.
How do i manage to start from that slected line?
Rainer
Rainer
- RobC
- Thank you received: 5
01 Dec 2022 18:35 #258244
by RobC
Replied by RobC on topic how to start an .ngc file somewhere in the middle?
In Axis, if you right click on the line number in the bottom part where the gcode is displayed, you will have the option to click "Run from here" in the popup menu. It will run from there without having to click start. Be sure your spindle / router is up to speed and you start on a Z up move so that your bit doesn't plunge into the work.
- Wusel
02 Dec 2022 06:33 #258299
by Wusel
Replied by Wusel on topic how to start an .ngc file somewhere in the middle?
great, i'll give it a try right away
Rainer
Rainer
- Wusel
04 Dec 2022 15:22 #258510
by Wusel
I've tried it now . However, the program alwasy jumps to the top line and starts from there?
Any guess, why?
Any guess, why?
06 Dec 2022 00:38 #258639
Replied by andypugh on topic how to start an .ngc file somewhere in the middle?
No idea, it just worked for me when I tried it.
Which GUI are you using?
- Thank you received: 7488
06 Dec 2022 11:04 #258689
Replied by tommylight on topic how to start an .ngc file somewhere in the middle?
Left click on the line first, then right click and choose run from here.
- Wusel
06 Dec 2022 13:09 #258694
by Wusel
Iam using Axis
- MarkoPolo
- Thank you received: 90
06 Dec 2022 23:40 #258766
by MarkoPolo
Replied by MarkoPolo on topic how to start an .ngc file somewhere in the middle?
I tested a bit and for me the "start from line" option works very badly. With the XYZ axes, when machining the bas-relief, the cutter passes through the material and destroys the entire work before it starts working properly a few or a dozen lines below. It's the same on axis and qtdragon.
- scotth
- Thank you received: 62
06 Dec 2022 23:56 #258768
by scotth
Replied by scotth on topic how to start an .ngc file somewhere in the middle?
Best to start at the first block after a tool change. That can get you in trouble still if there is no move in a clear plane to establish a safe path back to the part.
- Wusel
07 Dec 2022 13:58 #258807
by Wusel
I've tried it now a couple of times. Selecting the line first, then start from this line - the result is alwys the same, the program starts right from the beginning. misterious. would a different GUI be better?
Time to create page: 0.187 seconds
