how to start an .ngc file somewhere in the middle?
01 Dec 2022 18:02 #258238 by Wusel
dear all,
here comes a simple question regarding the use of Linuxcnc:
I want to run an ngc file not from the start but from somewhere further down the line. If i select the line and press the start button it jumps back to the top and starts from there.
How do i manage to start from that slected line?
Rainer
01 Dec 2022 18:35 #258244 by RobC
In Axis, if you right click on the line number in the bottom part where the gcode is displayed, you will have the option to click "Run from here" in the popup menu. It will run from there without having to click start. Be sure your spindle / router is up to speed and you start on a Z up move so that your bit doesn't plunge into the work.
02 Dec 2022 06:33 #258299 by Wusel
great, i'll give it a try right away
Rainer
04 Dec 2022 15:22 #258510 by Wusel
I've tried it now . However, the program alwasy jumps to the top line and starts from there?
Any guess, why?
06 Dec 2022 00:38 #258639 by andypugh
No idea, it just worked for me when I tried it.
Which GUI are you using?
06 Dec 2022 11:04 #258689 by tommylight
Left click on the line first, then right click and choose run from here.
06 Dec 2022 13:09 #258694 by Wusel
Iam using Axis
06 Dec 2022 23:40 #258766 by MarkoPolo
I tested a bit and for me the "start from line" option works very badly. With the XYZ axes, when machining the bas-relief, the cutter passes through the material and destroys the entire work before it starts working properly a few or a dozen lines below. It's the same on axis and qtdragon.
06 Dec 2022 23:56 #258768 by scotth
Best to start at the first block after a tool change. That can get you in trouble still if there is no move in a clear plane to establish a safe path back to the part.
07 Dec 2022 13:58 #258807 by Wusel
I've tried it now a couple of times. Selecting the line first, then start from this line - the result is alwys the same, the program starts right from the beginning. misterious. would a different GUI be better?
Time to create page: 0.183 seconds
