MPG Handwheel - how to use encoder?
- frogandspanner
02 Dec 2022 18:58 - 05 Dec 2022 00:13 #258345
by frogandspanner
MPG Handwheel - how to use encoder? was created by frogandspanner
I bought one of the MPG handwheels (rather like the ISM8060 at www.machinetoolproducts.com/content/Yumo...s%20Spec%20Sheet.jpg)
I have connected this to a parallel port, (A, B and gnd) and power it from a bench supply at 5V.
Then:Using halmeter I can see that encoder.0.phase-A and encoder.0.phase-B are being detected.
From reading various examples I assumed that encoder.0.counts would change as I operated the wheel, but it doesn't - and no other encoder pin does. I then
setp encoder.0.counter-mode TRUE
and still get no changes on any pins.
As the inputs change and are detected (at least at the hal pin level), and I get no output even in counter-mode, I assume I am doing something wrong.
Then:
$ halrunloadrt hal_parport cfg="0x3030 out"
loadrt encoder num_chan=1
net mpg-a encoder.0.phase-A <= parport.0.pin-10-in
net mpg-b encoder.0.phase-B <= parport.0.pin-11-in
loadusr halmeterFrom reading various examples I assumed that encoder.0.counts would change as I operated the wheel, but it doesn't - and no other encoder pin does. I then
Last edit: 05 Dec 2022 00:13 by andypugh.
- Thank you received: 5308
02 Dec 2022 21:10 #258367
Replied by PCW on topic MPG Handwheel - how to use encoder?
There are two encoder functions that must be added for the
encoder to operate:
addf encoder.capture-position servo-thread
addf encoder.update-counters base-thread
encoder to operate:
- frogandspanner
02 Dec 2022 22:05 #258375
by frogandspanner
Replied by frogandspanner on topic MPG Handwheel - how to use encoder?
No joy:
halcmd: addf encoder.capture-position servo-thread
HAL: ERROR: thread 'servo-thread' not found
<stdin>:5: addf failed
halcmd: addf encoder.update-counters base-thread
HAL: ERROR: thread 'base-thread' not found
<stdin>:6: addf failed
02 Dec 2022 22:16 #258377
If you have other names for your fast (base) and slow (servo)
threads, you must use those
- frogandspanner
02 Dec 2022 22:24 #258378
by frogandspanner
Do threads exist by defaul,t or must they be created? If the latter how is that done?
02 Dec 2022 22:39 #258379
They need to be created, If you have a parallel port step/dir hardware,
you should use stepconf to create a hal/ini configuration file set
that takes care of these details
- frogandspanner
02 Dec 2022 22:48 #258382
by frogandspanner
I was hoping to shortcut that process and just use halrun. I managed to (I think) work out some things:
loadrt threads name1=base-thread period1=50000 name2=servo-thread period2=1000000
loadusr halmeter
But encoder.0.counts refuses to budge when I rotate the wheel.
loadusr halmeter
02 Dec 2022 22:58 #258384
I think you need to start the threads
(I don't recall exactly how, it may be as simple as typing "start")
- frogandspanner
03 Dec 2022 16:44 #258438
by frogandspanner
I got it working with this:
$ halrun -I -f ptest.hal
net pin10 encoder.0.phase-A
net pin11 encoder.0.phase-B
loadusr halmeter
# Add encoder routines to the porttest thread from ptest.hal
addf encoder.update-counters porttest
addf encoder.capture-position porttest
loadusr halmeter
- Thank you received: 4648
05 Dec 2022 00:16 #258541
Replied by andypugh on topic MPG Handwheel - how to use encoder?
I tend to just "loadrt threads" which gives you one thread (called "thread1") but all that was missing from your code above was "start" to start the threads.
loadusr halmeter
startPlease Log in or Create an account to join the conversation.
Time to create page: 0.134 seconds
