Z AXIS DOES NOT GO UP OR DOWN WITH THC
09 Dec 2022 16:05 - 09 Dec 2022 16:09 #259010 by chuben
Hello:
I have a problem with THC. On the Qtplasma screen, it shows the volts correctly, but the Z axis does not move to follow the cutting height. What could be happening to me? Thank you
File Name: ChubenCNC_...6.tar.gz
File Size:14 KB
Last edit: 09 Dec 2022 16:09 by chuben.
  • Moderator
  • Moderator
09 Dec 2022 18:08 #259024 by tommylight
Replied by tommylight on topic Z AXIS DOES NOT GO UP OR DOWN WITH THC
I have no idea!
Your CAPS lock is stuck for sure, though.
Saying it does not work reallu does not help us help you, so:
-Does the Z axis work properly, going down on minus direction and up on positive direction?
-What voltage is shown on screen while plasma is cutting and vhat voltage you have set in the run panel/tab?
-Does the THC active LED come on while cutting?
-What feed rate are you cutting at and what feed rate is set in the run tab?
-Does the Void lock/VAD stay on all the time while cutting? If yes, lower the VAD value in the settings page from 95 to 65%.
-Disable Void crossing
Etc, etc...
Time to create page: 0.107 seconds
