Control from a Festo valve terminal
09 Dec 2022 16:19 #259011 by mgm
Some time ago I read something here in the forum about controlling FESTO valve terminals.
Who can tell me where I can find that?
Thanks!
09 Dec 2022 16:39 #259012 by Aciera
Replied by Aciera on topic Control from a Festo valve terminal
If you are referring to the valve blocks connected by Profibus then this could be it:
forum.linuxcnc.org/10-advanced-configura...-and-profibus#223639
The following user(s) said Thank You: mgm
  • Moderator
  • Moderator
09 Dec 2022 17:50 #259022 by tommylight
Replied by tommylight on topic Control from a Festo valve terminal
Also, RotarySMP uses Festo valves on his lathe, but i think those are normal valves with on/off control, not serial or anything-bus.
Not sure though...
11 Dec 2022 14:05 #259191 by mgm
Replied by mgm on topic Control from a Festo valve terminal
Thanks for the info ....
I have now downloaded the zip file for the Profibus and wanted to look with the demo, unfortunately without success ...
I have unzipped the zip and copied to my config folder and started via Linuxcnc the sim unfortunately I get an error message:
Debug file information:
setup_kins: cmd=loadrt trivkins
Note: Using POSIX realtime
motion.c: Creating unlock hal pins for joint 4
./profibus.hal:17: execv(pyprofibus-linuxcnc-hal): No such file or directory
./profibus.hal:17: waitpid failed pyprofibus-linuxcnc-hal profibus
./profibus.hal:17: pyprofibus-linuxcnc-hal exited without becoming ready
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
8269
Stopping realtime threads
Unloading hal components
Can anyone help me?
11 Dec 2022 14:34 #259193 by Aciera
seems that it can't find the file 'pyprofibus-linuxcnc-hal'. Are you sure the file is where you are telling it to look (ie the path set in 'profibus.hal') ?
11 Dec 2022 14:56 - 11 Dec 2022 15:25 #259194 by mgm
yes the file "pyprofibus-linuxcnc-hal" is in the same place as the file "linuxcnc-demo.ini
this is the line 17 in the "profibus.hal"
loadusr -Wn profibus pyprofibus-linuxcnc-hal pyprofibus.conf
Last edit: 11 Dec 2022 15:25 by mgm.
12 Dec 2022 07:11 - 12 Dec 2022 07:11 #259244 by Aciera
Not sure, maybe try with absolute paths. ie /home/<your-path-here>/pyprofibus-linuxcnc-hal
Last edit: 12 Dec 2022 07:11 by Aciera.
14 Dec 2022 01:44 #259391 by andypugh
Replied by andypugh on topic Control from a Festo valve terminal
It's trying to execute pyprofibus-linuxcnc-hal. Is it an executable file?
15 Dec 2022 08:21 #259544 by mgm
yes it is
I have now tried various ways to place the file without success!
I put this back for now!
17 Dec 2022 10:07 #259722 by Aciera
make sure that 'pyprofibus-linuxcnc-hal' is the actual file name (ie no extension)
If it got saved as pyprofibus-linuxcnc-hal.py (ie with extension) it won't be foundl.
I find it useful sometimes to use 'cat' in the terminal:
$ cat /home/<yourpathere>/pyprofibus-linuxcnc-hal
if it can't find the file then there is something wrong with the filename.
Time to create page: 0.395 seconds
