Build 2.9 RIP in Debian 12 without Documents
3 years 10 months ago #259095 by JT
So how do you build 2.9 RIP in Debian 12 without Documents?
What I have so far is:
sudo apt install libpython3.11 tcl-devĀ  tk-dev libreadline-dev libxmu-dev
./configure --disable-build-documentation-translation --with-realtime=uspace --enable-non-distributable=yes
The no-docs flag seems to not work anymore.
JT
3 years 10 months ago #259100 by JT
This did work however with 2.9
./autogen.sh ./configure --enable-build-documentation=no make sudo make setuid cd .. . ./scripts/rip-environment linuxcnc
JT
3 years 10 months ago #259103 by JT
This seems to work as well
JT
2 years 3 months ago #304528 by tjtr33
failed and the configurator said to add
resulting in:
/configure --with-realtime=uspace --enable-build-documentation=no --enable-non-distributable=yes
which worked fine
HTH
tomp
The following user(s) said Thank You: tommylight, JT
Time to create page: 0.229 seconds
