Customized Gscreen for gear Hobbing machine
- Thank you received: 4654
19 Dec 2022 22:50 #259902
Did you look there?
Replied by andypugh on topic Is there a way to disable one axis?
They would normally have been copied into your ~/linuxcnc/configs folder.
Did you look there?
- Henk
- Thank you received: 92
21 Dec 2022 05:17 #259995
by Henk
Replied by Henk on topic Is there a way to disable one axis?
HI Andy
It was the first place i looked.
The doc you posted helps, others too.
You have to copy the files from /usr/share/Gscreen....manually if you want to customise thhem.
Ill post progress....
- Thank you received: 7478
21 Dec 2022 14:04 #260009
Replied by tommylight on topic Is there a way to disable one axis?
Spammer booted.
- Henk
23 Dec 2022 05:28 #260140
by Henk
Replied by Henk on topic Customized Gscreen for gear Hobbing machine
HI
Ok, so i have looked at Gscreen and installed Glade.
I think the Industrial version is a good starting point. One thing i could not figure out immediately was how to adapt Gscreen to suit my screen resolution. The widgets are a bit out of place and it doesnt use the entire screen area effectively.
Do i have to play around in Glade to fix this or is there a better way?
I know about this document, are there any other information available? linuxcnc.org/docs/stable/html/gui/gscreen.html
- Thank you received: 2181
23 Dec 2022 05:59 #260141
Replied by cmorley on topic Customized Gscreen for gear Hobbing machine
gscreen is built on top of gladevcp. Gladevcp uses pygtk.
So gladevcp docs in linuxcnc might help a bit and pygtk tutorials can be helpful too.
- Henk
26 Dec 2022 05:47 #260298
by Henk
HI
I started playing with the industrial_handler.py and industrial glade files.
What i would like to achieve is to change the "setup" tab (man mode) to include the gear hobbing setup parameters similar to Andy's hobbing screen.
As a first step, i tried to remove the gremlin preview from the setup (man mode) tab, but keep it in the auto tab and MDI tab.
The show_box that contains gremlin is in notebook_main, page 0, so it stays with the main screen. I would like to move it to notebook_mode, but not sure how to achieve this. I can cut/paste it in glade, and i think it is ok, but i dont understand how the following code works to specify what is displayed when the different tabs are selected.
Would you mind explaining how "self.data.mode_order" functions, bearing in mind my limited, but developing python knowledge
# display the main tab and set the mode to setup
def on_setup_button_clicked(self,widget):
self.widgets.notebook_main.set_current_page(0)
self.data.mode_order = _MAN,_MDI,_AUTO
label = self.data.mode_labels
self.widgets.button_mode.set_label(label[self.data.mode_order[0]])
self.gscreen.mode_changed(self.data.mode_order[0])
self.toggle_modes(widget)
# display the main tab and set the mode to run
def on_run_button_clicked(self,widget):
self.data.mode_order = _AUTO,_MAN,_MDI
# display the main tab and set the mode to MDI
def on_mdi_button_clicked(self,widget):
self.data.mode_order = _MDI,_MAN,_AUTO
self.toggle_modes(widget)Please Log in or Create an account to join the conversation.
26 Dec 2022 06:45 - 26 Dec 2022 06:46 #260300
It's been awhile since being in the code...
mode_order is the variable that holds the order of machine modes: Manual, MDI, and Auto.
Originally thought to be toggled through.
But this is the code you probably want to see - it's in gscreen.py
If you open a terminal and type:
gscreen -F | more
You can see some more information on gscreen's functions - or just look at the source code.
# adjust the screen as per each mode toggled
def mode_changed(self,mode):
if mode == self.data._MAN:
self.widgets.vmode0.show()
self.widgets.vmode1.hide()
self.widgets.notebook_mode.hide()
self.widgets.hal_mdihistory.hide()
self.widgets.button_homing.show()
self.widgets.dro_frame.show()
self.widgets.spare.hide()
elif mode == self.data._MDI:
if self.widgets.button_homing.get_active():
self.widgets.button_homing.emit("clicked")
if self.data.plot_hidden:
self.toggle_offset_view()
self.emc.set_mdi_mode()
self.widgets.hal_mdihistory.show()
elif mode == self.data._AUTO:
self.widgets.vmode0.hide()
self.widgets.vmode1.show()
if self.data.full_graphics:
else:
self.widgets.notebook_mode.show()
if not mode == self.data._MAN:
self.widgets.button_jog_mode.set_active(False)
self.widgets.button_homing.set_active(False)
self.widgets.button_homing.hide()
self.widgets.spare.show()
for i in range(0,3):
if i == mode:
self.widgets["mode%d"% i].show()
else:
self.widgets["mode%d"% i].hide()If you open a terminal and type:
gscreen -F | more
Last edit: 26 Dec 2022 06:46 by cmorley.
The following user(s) said Thank You: Henk
- Henk
31 Dec 2022 05:09 #260608
by Henk
Update and another question.
I tried to understand the python files, although i can read the code and sort of understand how it functions, im finding it hard to add additional functionality. Because of that, i found a workaround that works for me, and that is to use the hal widgets to create a UI page where i can interact directly with hal. I have to write a realtime comp for the hobbing axes syncronisation anyway so i can use that to do some of the checks and calculations and display the results on Gscreen after linking throug hal again......Ugly, i know but it works for me.
Now another question.
Gscreen (industrial) is designed for a touch screen interface. There are a couple of things i want to link to hardware buttons.
Axis selection, for example. I have a rotary switch that selects x,y,z,a and c axes for my mpg and jog buttons (+ and -). I want this selection to select the axis on the gui without having to click that axis on the setup page. So i need to add hal pins for selecting the axis according to the switch position.
Is this something that should go in the handler py file or would it require changes in gscreen.py?
01 Jan 2023 01:15 #260689
extra pins go in the handler.
Something like this should work:
import hal_glib
def __init__(self, halcomp,builder,useropts,gscreen):
self.emc = gscreen.emc
self.data = gscreen.data
self.widgets = gscreen.widgets
self.gscreen = gscreen
self.halcomp = halcomp # <-----
def initialize_pins(self):
self.gscreen.initialize_pins()
for axis in self.data.axis_list:
self.data['jog-select-%s'% axis] = hal_glib.GPin(self.halcomp.newpin('jog-select-%s'% axis, hal.HAL_S32, hal.HAL_IN))
self.data['jog-select-%s'% axis].connect('value-changed', self.on_hal_jog_select_changed)
def on_hal_jog_select_changed(self,gpin):
print(gpin.get_name())
pin = 'jog-select-%s'% axis
# does the changed pin match list ?
if gpin.get_name() == pin:
# and the pin true
if gpin.get():
self.widgets['axis_%s'%axis].set_active(1)
self.gscreen.update_active_axis_buttons(self.widgets['axis_%s'%axis])
# else clear HAL pin and widget
else:
self.widgets['axis_%s'%axis].set_active(0)
self.data['jog-select-%s'% axis].set(0)
else:
- Henk
02 Jan 2023 09:04 - 02 Jan 2023 09:15 #260755
by Henk
HI Chris. Thank you for this. It works, apart from one issue. When the axis selection goes up in the list, i.e from x - y - z ... it works as expected and the buttons are active according to the hal signals. But when going down on the selection list, for example from z back to y, all the buttons on the gui are inactive. so it seems that the button state is only updated when selecting the next axis higher up in the list, not when going down. Reading the code, it is not clear (to me) why it behaves like this.
I have encountered two other issues with homeing.
My machine axis/joint configuration is xyzac => joint 0 to joint 4. When i want to home a single axis from the gui, X,Y,Z and A homes as expected, but no response from the C axis. I found that Gscreen wants to home joint 5 when i try to home the c axis, of course joint 5 does not exist.
I think this is an issue in gscreen.py because in the list "xyzabcuvw", c would be joint 5. I guess this because it was written way before the joint/axis split.
Joint 4 (c) in my config is set up to home immediately. When i click the home-all button, it homes as expected, but because the x and y axis on this machine works from the same drive, they cannot operate together and have to be selected. I can probably automate this in HAL so that home all works, but i would like to be able to home selected axes as well.
edit: the other issue is that the " * " indicator for axis homed only show next to the last homed axis. It doesnt show when the next axis homes
How can we fix this?
Can i define the c axis as joint 5 in my ini file, without a joint 4? have not tried this
Last edit: 02 Jan 2023 09:15 by Henk.
Time to create page: 0.337 seconds
