Linuxcnc after cloning the disk with Clonezilla, the motors of the X Y Z no work
17 Dec 2022 18:08 - 17 Dec 2022 18:16 #259752 by jarcysgru
I cloned the ATA drive to a new SSD to have a spare, then started linuxcnc and I have no reaction of the X Y Z axis motors.
Interestingly, I checked this new SSD on the second computer, which I have a working linuxcnc with the configuration of the lathe on the SSD and all axle motors don't work for me either
What is wrong ?
Last edit: 17 Dec 2022 18:16 by jarcysgru.
  • Moderator
  • Moderator
17 Dec 2022 19:20 #259760 by tommylight
17 Dec 2022 20:48 - 17 Dec 2022 21:11 #259765 by jarcysgru
Sklonowany system to płyta
2.7.14 D945GCLF2D
Last edit: 17 Dec 2022 21:11 by jarcysgru.
17 Dec 2022 21:17 #259767 by jarcysgru
17 Dec 2022 21:50 #259769 by jarcysgru
The disk from the linuxcnc machine that I cloned is ATA and the board is GA-7VASFS-FS 60GB
The new drive with which I have such problems is the SSD Patriot P210 128GB
The board to which I mounted the cloned (new) disk is
D945GCLF2D. On the same board (D945GCLF2D) as I mentioned, I have a working linuxcnc 2.7.14 lathe and after connecting this new disk there is this problem.
And I forgot when I have linuxcnc on and how to move the axes
the - or + button changes the position of the axis on the screen (the coordinates of the axis change) but as I wrote earlier, the motors of all axes are stopped.
I have attached pics of my bios settings
  • Moderator
  • Moderator
17 Dec 2022 23:07 - 17 Dec 2022 23:14 #259775 by tommylight
Are you using a parallel port?
Assuming you are, so in a terminal:
sudo cat /proc/ioports | grep parport
and
sudo lspci -v | grep par
Paste the results from both drives and both PC's here.
Last edit: 17 Dec 2022 23:14 by tommylight. Reason: more info
18 Dec 2022 12:03 #259816 by jarcysgru
Yes, I use LPT ports.Returns the results of commands.
File Name: Nowykomuter.zip
File Size:3 KB
File Name: Starykomut...arki.zip
File Size:1 KB
18 Dec 2022 12:06 #259817 by jarcysgru
jarcysgru post=259816 identyfikator użytkownika=2779Tak, używam portów LPT. Zwraca wyniki poleceń.
New computer
File Size:3 KB
Old computer
File Size:1 KB
  • Moderator
  • Moderator
18 Dec 2022 12:14 #259818 by tommylight
04:00.0 Parallel controller: SUNIX Co., Ltd. Multiport serial controller (prog-if 03 [IEEE1284])
	Subsystem: SUNIX Co., Ltd. Device 0100
	Flags: medium devsel, IRQ 10
	I/O ports at 1018 [size=8]
	I/O ports at 1010 [size=8]
	I/O ports at 1000 [size=16]
	Capabilities: [40] Power Management version 3
Change the address in the ini file, one of the PC has a built in parallel port at 0x378 the other has an add on card that should be set st 0x1018
18 Dec 2022 14:49 #259821 by jarcysgru
I give a hal file and in it I have port 0x378 set.
This second lathe computer has a second 1018 card for the encoder.
File Name: huanyang.hal
File Size:3 KB
Time to create page: 0.410 seconds
