MESA THCAD-2 - couple quick questions
- Doug @ Design8Studio.com
- Thank you received: 46
26 Dec 2022 09:15 - 26 Dec 2022 09:30 #260302
by Doug @ Design8Studio.com
MESA THCAD-2 - couple quick questions was created by Doug @ Design8Studio.com
Hello and thanks for being so awesome. Hope you all had a merry Christmas.
I'm building a CNC plasma based on the LowRider v3 motion control system, guided by a previous build by Kyle (@kd2018 at the V1E forum) which was based on the LowRider v2 motion control system.
Kyle had shared an immensely helpful wiring diagram image, which I have copied and tweaked to match my specifics (somewhat).
Where Kyle used MESA THCAD-10 ... mine is THCAD-2. His diagram calls for grounding ("to star ground") from the analog ARC input area of the THCAD-10. See below. However, according to the manual for THCAD-2, the two center connections (other than + and -) are "unused" — do I need to find some way to ground via somewhere else? Or can I ignore that part?
Where Kyle used MESA 7i96 mine is 7i96S. I do not know if this requires any changes. See below. ??
Below are Kyle's original diagram and my tweaked version.
KYLE's diagram:
My Diagram:
KYLE's diagram:
My Diagram:
Last edit: 26 Dec 2022 09:30 by Doug @ Design8Studio.com. Reason: fixed typos
The following user(s) said Thank You: Bjornstabo
- voltaicsca
- Thank you received: 5
26 Dec 2022 09:53 #260303
by voltaicsca
Replied by voltaicsca on topic MESA THCAD-2 - couple quick questions
From the docs, it looks like the THCAD-10 had integrated resistors, and is doing the voltage dividing on-board, which given the voltages (and likely noise) probably needs a strong power-ground plane to keep noise out of the rest of the circuit. The THCAD-2 requires an external resistor and probably assumes that the HIGH voltage electrical noise will be far enough away from the rest of the board to not need it.
The board has a ground *reference* through the signal ground to the rest of the system, so I'd assume you're ok without wiring to "star" ground.
If you're worried, you can look at the traces from those two center terminals that would have been to ground on the *-10 part, and see what the connect to, and use that to make an informed decision. Generally, though, if the designer says they're unused, they mean it.
I'm new here, btw, so take this with a grain of salt. Maybe PCW will chime in with an authoritative answer.
The following user(s) said Thank You: Doug @ Design8Studio.com
- Thank you received: 7478
26 Dec 2022 11:26 #260307
Replied by tommylight on topic MESA THCAD-2 - couple quick questions
So far i never needed to wire ground to THCAD, and i have installed over 15 of those.
But, i mount THCAD to the back of the plasma source.
If mounting it inside a cabinet, grounding it is a good practice.
The star ground reffers to a single point where all the ground wires bolt inside the cabinet, or a ground rail.
- Thank you received: 4149
26 Dec 2022 11:49 - 26 Dec 2022 11:50 #260316
Replied by rodw on topic MESA THCAD-2 - couple quick questions
+1 for Tommy.
Initially, I grounded the THCAD HV side but found due to a mains bond from neutral to ground in the building switchboard was part of our standard wiring in .AU. I found that this introduced a 50 Hz ripple in the torch voltage (from the mains ground) so I don't do it anymore either.
Last edit: 26 Dec 2022 11:50 by rodw.
26 Dec 2022 14:38 #260328
Replied by Doug @ Design8Studio.com on topic MESA THCAD-2 - couple quick questions
Thank you so much
26 Dec 2022 14:40 #260329
Thank you, I appreciate it!
26 Dec 2022 14:43 #260330
Got it. Thank you!
In the somewhat related 2nd question, are there any significant differences between the MESA 7i96 and 7i96S? That would affect the wiring scheme?
- Thank you received: 5326
26 Dec 2022 16:44 - 26 Dec 2022 16:46 #260332
Replied by PCW on topic MESA THCAD-2 - couple quick questions
The THCAD2 does not need a input side ground.
(the + input is the analog input reference/ground)
The 7I96S wiring should be identical to the 7I96 with one exception:
It's better to use output 4 or 5 for plasma connections as they have better
isolation and will couple less plasma noise into the rest of the system.
(as long as the 100 mA output current limitation of outputs 4/5 is not an issue)
Last edit: 26 Dec 2022 16:46 by PCW.
The following user(s) said Thank You: tommylight, Doug @ Design8Studio.com
26 Dec 2022 17:27 #260333
26 Dec 2022 21:09 #260346
Yes
Time to create page: 0.353 seconds
