MESA THCAD-2 - couple quick questions
3 years 10 months ago #260330 by Doug @ Design8Studio.com
Got it. Thank you!
In the somewhat related 2nd question, are there any significant differences between the MESA 7i96 and 7i96S? That would affect the wiring scheme?
3 years 10 months ago - 3 years 10 months ago #260332 by PCW
The THCAD2 does not need a input side ground.
(the + input is the analog input reference/ground)
The 7I96S wiring should be identical to the 7I96 with one exception:
It's better to use output 4 or 5 for plasma connections as they have better
isolation and will couple less plasma noise into the rest of the system.
(as long as the 100 mA output current limitation of outputs 4/5 is not an issue)
Last edit: 3 years 10 months ago by PCW.
The following user(s) said Thank You: tommylight, Doug @ Design8Studio.com
3 years 10 months ago #260333 by Doug @ Design8Studio.com
@PCW
Thank you! So, based on my screen shot below, am I understanding you correctly on what change needs made?
image missing http://design8studio.com/files/Screen-Shot-2022-12-26-at-12.25.02-PM.png
3 years 10 months ago #260346 by PCW
Yes
The following user(s) said Thank You: Doug @ Design8Studio.com
3 years 10 months ago #260437 by Doug @ Design8Studio.com
Thanks again, to all.
My build progress can be followed here: forum.v1engineering.com/t/lowrider-3-pla...arksburg-wv/33849/77
3 years 10 months ago #260441 by tommylight
Great job, thank you.
Seen this before, nice to see you keep it up to date always. :)
Time to create page: 0.195 seconds
