hand wheel correct steps per impulse
- theliadir
27 Dec 2022 19:26 #260425
by theliadir
hand wheel correct steps per impulse was created by theliadir
Hello
I am using a WHB04B-6 hand wheel (like this one) and I was able to make it work with the template and a bit of help on youtube.
I opperate the machine in a metric enviroment and when we turn the wheel it takes not metric steps.
Is there any way to adapt the steps per impulse?
I read the documentation linuxcnc.org/docs/stable/html/man/man1/xhc-whb04b-6.1.html
Has it do to with whb.axis.<N>.jog-counts (s32,out) maybe?
or whb.axis.<N>.jog-scale (float,out)?
or whb.halui.feed-override.scale (float,in)?
Any hints in the right direction are appreciated.
- chris@cnc
- Thank you received: 140
28 Dec 2022 16:42 #260478
by chris@cnc
Replied by chris@cnc on topic hand wheel correct steps per impulse
Yes, these pins could be your problem or the ilowpass scale + gain if you use. Search here in forum. You will find a lot of examples...
The following user(s) said Thank You: theliadir
- theliadir
29 Dec 2022 09:12 #260498
by theliadir
Replied by theliadir on topic hand wheel correct steps per impulse
Thank you very much. I will look into that.
- Online
- Thank you received: 7462
04 Jan 2023 21:35 #260969
Replied by tommylight on topic hand wheel correct steps per impulse
Spammer booted.
- Online
12 Jan 2023 16:38 #261709
Spammer booted.
Not a duplicate post.
Time to create page: 0.590 seconds
