Resistive touch screen calibration
  • Axolito
  • Axolito's Avatar Topic Author
  • Junior Member
  • Junior Member
04 Jan 2023 11:41 #260916 by Axolito
Resistive touch screen calibration was created by Axolito
Hello,I have just installed a PC with the last ISO of LinuxCNC available on the site.I use a resistive touch screen from a store checkout. Unfortunately, it is not correctly calibrated, the pointer is always next to the place where you press with your finger.How should touchscreens be calibrated on ISO LinuxCNC (debian 10 I think)? Could you detail me the procedure to follow please?
  • Moderator
  • Moderator
04 Jan 2023 11:59 #260918 by tommylight
Replied by tommylight on topic Resistive touch screen calibration
On the phone so can not help much, but search for touchscreen calibration Debian Buster.
Xinput comes to mind.
  • Moderator
  • Moderator
04 Jan 2023 16:48 #260940 by tommylight
  • Axolito
  • Junior Member
  • Junior Member
04 Jan 2023 19:10 #260952 by Axolito
Replied by Axolito on topic Resistive touch screen calibration
Hello, thank you for your answer. I searched and found the same results on google, it took me a little while to understand how it works.
But I could not solve my problem.
04 Jan 2023 22:08 #260971 by JPL
Replied by JPL on topic Resistive touch screen calibration
That would help knowing which touch screen driver (hardware) you have. For example, the eGalax touch screen driver is used by many touch screen manufacturers, such as Advantech. In this case you will be able to find a perfectly working driver for many linux version, including Debian, here: www.eeti.com/drivers_Linux.html. This comes with a utility for screen calibration and more.
The following user(s) said Thank You: Axolito
  • Axolito
  • Junior Member
  • Junior Member
05 Jan 2023 07:33 #260982 by Axolito
Thank you very much for this link. My screen is indeed recognized as an "eGalax".
When I finish the rest of my CNC (I'm in the process of wiring) I will try to calibrate the touch screen again.
  • Axolito
  • Junior Member
  • Junior Member
19 Nov 2024 15:56 #314854 by Axolito
A lot of time went by, I tried several things and finally found a documentation that worked for me:
www.katjaas.nl/linux/touch.html
From this I was able to create a desktop launcher that launches a touchscreen calibration, stores the calibration data and applies it immediately.
I've shared the launcher file, otherwise, here's the command (which works in my case):
/bin/sh -c "xinput_calibrator --misclick 50 --output-filename /usr/share/X11/xorg.conf.d/80-touchscreen.conf"
Time to create page: 0.117 seconds
