Setting Linuxcnc 2.9 to open up after debian boots up
- bbrein8747
- Thank you received: 3
06 Jan 2023 01:44 #261054
by bbrein8747
Setting Linuxcnc 2.9 to open up after debian boots up was created by bbrein8747
Does anyone know how to set up Linuxcnc 2.9 to auto start after the Debian is done booting up? I have the computer and monitor set to start when the power is turned on, and the Debian is starting and auto logging in at boot up, Now I just need to tweak the Linuxcnc to auto start so the operator will only have to clear the E-stop and home the machine and it should be golden.
- bbrein8747
06 Jan 2023 02:41 #261058
by bbrein8747
Replied by bbrein8747 on topic Setting Linuxcnc 2.9 to open up after debian boots up
Got it, through the Start Up application I was able to launch it after boot up with just enough delay to give the Ethernet connection time to go live.
- Thank you received: 7462
06 Jan 2023 11:14 #261074
Replied by tommylight on topic Setting Linuxcnc 2.9 to open up after debian boots up
Yup, thait is it.
There is also a small script here made by PCW that keeps checking for Mesa ethrnet by pinging and starts LinuxCNC after it gets a reply.
On the phone...
On the phone...
The following user(s) said Thank You: bbrein8747
- bbrein8747
17 Jan 2023 19:10 #262261
by bbrein8747
So I have the machine running (Hurco VM2-converted to riveter), finally. The MSI computer with the 8125 ethernet card did not make life easy, fortunately there was some info on the forums to help get around that. I ended up with bookworm and a patch from PCW and the QTdragon touch screen, but I am fighting a few issues on boot up. Seems like I am still missing something. After I get through this portion I will need to configure the tool changer.
Attachment not found
Time to create page: 0.097 seconds
