A techincal question on the Mesa 7i76e input limits
- Gorts Revenge
09 Jan 2023 04:11 #261326
by Gorts Revenge
A techincal question on the Mesa 7i76e input limits was created by Gorts Revenge
I recently had to interface a servo drive's encoder to the Mesa 7i76E board. I ended up using a high speed optocoupler and converting the signals to single ended inputs. The solution skirted the core question though, which is: Are the input voltage limits on the Mesa relative to the reference plane of the differential signal or Mesa's ground plane? In my case, the differential signal was almost thirty volts relative to "earth" while the differential of that voltage was only +/- 5V.
- Thank you received: 5328
09 Jan 2023 04:27 #261327
Replied by PCW on topic A techincal question on the Mesa 7i76e input limits
The common mode range of a 7I76E encoder input is +12 and -7V
30V is way outside of the limit.
Normally the common mode should be close to +2V.
30V likely means you have a missing ground that's needed establish
the common mode
the common mode
The following user(s) said Thank You: Gorts Revenge
- Gorts Revenge
09 Jan 2023 04:36 #261328
by Gorts Revenge
Replied by Gorts Revenge on topic A techincal question on the Mesa 7i76e input limits
It's a low-ball Chinese drive. They made the simulated encoder output isolated and didn't add a common ground point for that circuit. All the other inputs and outputs on the drive have a common but not that one. I scratched my head on it for a while and decided to take the safest path I could think of, which was an expensive signal optocoupler. It's good information though (save someone some expensive magic smoke and the fine smell of aldeheydes).
For the record, the low-ball Chinese AC servo drive runs great. Aside from some cryptic operating literature, it's fine.
Thanks.
Thanks.
