B Axis Limits 2.9
09 Jan 2023 18:47 #261373 by scotth
B Axis Limits 2.9 was created by scotth
Is there a way to increase B axis MIN_LIMIT and MAX LIMIT?
Something like this:    [JOINT_3]MIN_LIMIT > [AXIS_B]MIN_LIMIT (-9999.0 > -9999999.0)
                                    [JOINT_3]MAX_LIMIT < [AXIS_B]MAX_LIMIT (9999.0 < 9999999.0)
Profiling with B axis.
10 Jan 2023 06:52 #261428 by Aciera
Replied by Aciera on topic B Axis Limits 2.9
If you omit the limit settings for joint/axis it should use a value of 1e99 / -1e99.
Which is basically unlimited.
linuxcnc.org/docs/html/config/ini-config...t__lt_num_gt_section
The following user(s) said Thank You: scotth
Time to create page: 0.079 seconds
