Move the current file after job done
- mariusl
10 Jan 2023 17:17 #261474
by mariusl
Regards
Marius
www.bluearccnc.com
Move the current file after job done was created by mariusl
I asked this question in the Gmoccapy forum and afterwards realized that I should have asked here. I got good answers for the Gmoccapy screens but I dont know how it will work in Plasmac
I want to put a button on the screen that will move the current gcode file to a folder after the operator has cut the job.
Is it possible and how would one approach that if possible?
Regards
Marius
www.bluearccnc.com
- Thank you received: 4138
10 Jan 2023 19:28 #261484
Replied by rodw on topic Move the current file after job done
Its not quite the same, but the load latest button might be useful here.
I run Sheetcam on a Windows machine and save the output across the network into the nc_files folder.
THen go to the machine and press load latest.
There are other button options to run an external command which may let you achieve this.
linuxcnc.org/docs/devel/html/plasma/qtpl....html#qt_button-cmds
- mariusl
11 Jan 2023 06:19 - 11 Jan 2023 06:24 #261537
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Move the current file after job done
Rod I am still on Plasmac running on Linuxcnc 2.8.4. Don't know if it works the same there. I may have to use the Python interface to linuxcnc and the linuxcnc.stats module to get the file name.
I will have look to do some digging I think.
Regards
Marius
www.bluearccnc.com
Last edit: 11 Jan 2023 06:24 by mariusl.
Time to create page: 0.470 seconds
