SSI encoder
3 years 9 months ago - 3 years 9 months ago #262249 by PCW
Replied by PCW on topic SSI encoder
Also the documentation mentions a parity bit... Not sure if this is present or not
Replacing the "e" with a "g" in the format string will convert the encoders Gray code to binary
Last edit: 3 years 9 months ago by PCW.
3 years 9 months ago #262251 by nhanpham
Replied by nhanpham on topic SSI encoder
maybe. my encoder is a binary code.
Yes, this error just happens at startup. After it worked perfectly from the start pos, which it read during startup
thank you
3 years 9 months ago #262255 by PCW
So it only works properly after the encoder position changed?
A SSI encoder should always have a valid output
3 years 9 months ago #262295 by annhan
Replied by annhan on topic SSI encoder
Yes, it has an error in that it gets a different encoder value when I turn on the encoder power.After reading this value, the LinuxCNC worked normally and produced no errors.
thank you
3 years 9 months ago #262300 by PCW
LinuxCNC is reading the encoder 1000 times a second
When does the encoder value become correct?
3 years 9 months ago - 3 years 9 months ago #262301 by annhan
i  uploaded2 videos. At the same position,i get 2 value when i turn on power of encoder. It is Z-Axis.
1.
2.
Last edit: 3 years 9 months ago by annhan.
Time to create page: 0.312 seconds
