SSI encoder
3 years 9 months ago #262238 by nhanpham
SSI encoder was created by nhanpham
hi all,I have an ABS encoder, CAX60.My config in linuxcnc
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=0  num_stepgens=6  ssi_chan_0=ENC_ZH%24eENC_SIGN_Z%1b
# set speed
setp hm2_7i80.0.dpll.02.timer-us -300
setp hm2_7i80.0.ssi.00.frequency-khz 125
setp hm2_7i80.0.ssi.00.timer-number 2
setp hm2_7i80.0.ssi.00.ENC_ZH.counts-per-rev 4096
setp hm2_7i80.0.ssi.00.ENC_ZH.scale -32.25
However, I received a random encode value.
At home position:
When I open the linuxcnc and turn on power, I get the 0 value of encoder.
But sometimes i turn on linuxcn at this position and i get 250 value of encoder.
can you hel me check my config is correctly?
thank you so much
3 years 9 months ago #262239 by andypugh
Replied by andypugh on topic SSI encoder
Is the problem just the startup value, or does it not give useful output either?
ie, is it _always_ random, or just at startup?
3 years 9 months ago #262240 by nhanpham
Replied by nhanpham on topic SSI encoder
It is simply random when starting up.
thank you so much
3 years 9 months ago #262243 by PCW
Replied by PCW on topic SSI encoder
I would first try all 4 combinations of polarity
(all 4 combinations of swapped CLK+ and CLK- and swapped DATA+and DATA-)
Also its hard to tell from the awful data sheet, but it seems to be a Gray
coded encoder so your format string may not be correct.
3 years 9 months ago #262245 by nhanpham
Could you possibly give me a format for this encoder? i will test it tomorrow.
Thank you for your help.
3 years 9 months ago #262246 by andypugh
Apart from the startup value, does the position otherwise work, ie increases smoothly without jumps as it is turned?
