SSI encoder
18 Jan 2023 01:28 #262300 by PCW
Replied by PCW on topic SSI encoder
LinuxCNC is reading the encoder 1000 times a second
When does the encoder value become correct?
18 Jan 2023 01:30 - 18 Jan 2023 01:32 #262301 by annhan
Replied by annhan on topic SSI encoder
i  uploaded2 videos. At the same position,i get 2 value when i turn on power of encoder. It is Z-Axis.
1.
2.
Last edit: 18 Jan 2023 01:32 by annhan.
  • Moderator
  • Moderator
18 Jan 2023 02:51 #262315 by tommylight
Replied by tommylight on topic SSI encoder
Sorry for being blunt, but why are switching power off to encoders with "machine enable"?
Encoders should be powered on and stay on as long as Mesa boards are on.
I have used SSI (i think) serial absolute encoders, thanks to PCW, they are still in daily use for several years now, when the machine is first turned on the DRO shows some huge values, home all axis, and everything works perfectly.
Time to create page: 0.673 seconds
