Delta asd-b2
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Jan 2023 16:28 #262663 by billykid
Delta asd-b2 was created by billykid
hi, I have a Delta asd-b2 drive with a 400 watt motor, I wanted to use it for the spindle at low rpm but it can be controlled via rs 485 like the normal vfds like hy_vfd?. I don't think I've seen such a component for delta.
04 Feb 2023 12:19 #263668 by andypugh
Replied by andypugh on topic Delta asd-b2
You might be able to use the generic hal_modbus component?
  • billykid
  • Platinum Member
  • Platinum Member
04 Feb 2023 19:44 #263702 by billykid
Replied by billykid on topic Delta asd-b2
Thanks Andy, I thought the b2 model didn't have modbus like the a2.
however i fitted a parker dc 400 watt so i used the 7i40.
04 Feb 2023 21:37 - 04 Feb 2023 21:40 #263715 by chris@cnc
Replied by chris@cnc on topic Delta asd-b2
I think that's possible. But how to get this data in linuxcnc. Has someone examples?
Last edit: 04 Feb 2023 21:40 by chris@cnc.
  • billykid
  • Platinum Member
  • Platinum Member
05 Feb 2023 19:33 #263769 by billykid
I did some tests, with the delta software and a usb - rs232 adapter I tried to run it and everything works, then I loaded mb2hal on linuxcnc putting serial mode in the config.ini.
in the hal configuration all the pins appear but they are inactive, I also tried a usb stick - rs485 like the one I use for the huang yang vfd but it is the same.
for now I don't need it because I used another dc servo but in the future I will enjoy making it work if it is possible.
Time to create page: 0.149 seconds
