Named Parameter not defined error
26 Jan 2023 05:46 #262919 by SkyMoCo
Named Parameter not defined error was created by SkyMoCo
I am trying to pass a variable defined in the .ini file to a macro but I must be missing a step as when I run it, I get a not defined error for any variable I try to use, in this case max_probe.   From reading the docs and looking at example code, I think this should work.   If I define the variables inside the macro file, it works just fine, but I want to understand what I am doing wrong.
From my ini file:
[TOOLSENSOR]
max_probe = 10
And the macro has:
#<max_probe> = #<_ini[TOOLSENSOR]max_probe>
I read this to mean:
                                           ^--  Variable, converted to lowercase w/o underscores or spaces
  From the TOOLSENSOR part of the file
  From the ini file
26 Jan 2023 11:46 #262929 by mgm
Replied by mgm on topic Named Parameter not defined error
I had the same problem ... the missing an entry in the INI
under the section: [RS274NGC]
INI_VARS = 1
and for the HAL parameters
HAL_PIN_VARS = 1
linuxcnc.org/docs/2.9/html/config/ini-co...sub:ini:sec:rs274ngc
26 Jan 2023 17:06 #262942 by SkyMoCo
Replied by SkyMoCo on topic Named Parameter not defined error
That must be a new 2.9 feature. I'm still on 2.8. I'll upgrade and give it a go.
26 Jan 2023 18:13 #262949 by mgm
No you do not need updates !
My machine is also at 2.8
Just add the 2 lines in the ini and good !!!
