program suts down after I invoke Feedhold (or pause)
29 Jan 2023 17:49 #263172 by Ibmack
Hi,Apologies in advance for being unfamiliar with this forum and being a newbie on CNC. I run a sherline 4 axis cnc mill with linuxcnc. My problem is that whenever I use Feedhold (or Pause) to say pause a job overnight, the program shuts down and gives me an error report. Obviously this screws up my job. It has never shut down during a job, only if I use Feedhold or Pause and I don't know how long after I invoke those commands it takes for the program to shut down. I have the error report attached if that helps. I have run the latency test (not sure why that would be the problem) and report a max jitter rate of about 61,000 (base thread).Can anyone point me in the right direction to solving this problem?Thanks,Ian
29 Jan 2023 19:02 #263176 by cmorley
You are using 'Mini' screen and got a real time delay error.
Mini is very old and not included anymore so I can't comment why it shuts down.
The real time error means the computer sometimes has too much latency, which could be related to 'sleep' settings or other oddities. Is it a laptop?
Do you ever get a real time error while using the system?
You could try improve the latency problem and or update to a modern version of linuxcnc.
Or never leave it running overnight.
Others may have better ideas too.
29 Jan 2023 19:55 #263180 by Ibmack
Thank you for the feedback cmorley. I’ve only had the mill up and running for a few weeks having bought it new in the box from a guy that had it lying around for 12 or 13 years. It came with the Sherline build desktop computer. It is only running Linux OS. I upgraded Linuxcnc to the most recent version Sherline recommends, which I realize is not as current as it could be but maybe I should give that a try soon.
The program has never crashed while running. It has crashed four times in the last two weeks when I feed hold or pause (for any multi-hour period). No sleep settings on.
Yes unless I can find something concrete I will refrain from using feedhold for any long periods of time.
Thanks again. If anyone else may have some insight, I'm all ears.
Ian
29 Jan 2023 23:20 #263194 by cmorley
If you try updating , please use a different hardrive so you can switch back.
Updating a 12 year old version of linuxcnc could be a lot of effort.
The following user(s) said Thank You: Ibmack
Time to create page: 0.696 seconds
