Homing Joints
08 Feb 2023 19:09 #264071 by imslo
Homing Joints was created by imslo
I just finished putting my MPCNC together and made a configuration file.  Now when I open Linuxcnc I have to home all the joints before I can do anything else.  MPCNC has dual motors on X and Y.  Is this whats causing the problem is there any way to get around this homing?
  • Moderator
  • Moderator
08 Feb 2023 21:23 #264077 by tommylight
Replied by tommylight on topic Homing Joints
How are your drives/motors set up?
Do you have separate drives/motors for each side?
08 Feb 2023 21:43 #264078 by imslo
Replied by imslo on topic Homing Joints
I have a tb6600 driver for each of the 5 motors.
  • Moderator
  • Moderator
08 Feb 2023 23:39 #264080 by tommylight
Parallel port?
Mesa board?
Pico board?
Are the driver inputs separate for each drive?
09 Feb 2023 00:32 #264083 by imslo
Mesa 7i96 Board
TB1/TB2 Programmed as follows:
0: X Axis StepGen hooked to a TB6600 hooked to X Axis motor #1
1: X2 Tandem StepGen hooked to a TB6600 hooked to X Axis motor #2
2: Y Axis StepGen hooked to a TB6600 hooked to Y Axis motor #1
3. Y Tandem StepGen hooked to a TB6600 hooked to Y Axis motor #2
4. Z Axis StepGen hooked to a TB6600 Hooked to Z Axis motor
X and Y each has 2 motors and 2 drivers
Z has 1 motor and 1 driver
  • Moderator
  • Moderator
09 Feb 2023 01:44 #264087 by tommylight
You should have posted that on the first post.
Not being able to jog until the machine is homed when using tandem axis is a safety feature to prevent from raking the gantry.
If you try to jog with the machine not homed, only a single motor will move as it is still in Joint mode.
Probably there is a way to turn that off, but i never used it as i home the machines every time they are powered on and to prevent users from bending the expensive aluminium gantry.
09 Feb 2023 01:58 #264088 by imslo
I don't know what joint mode is but thanks for the reply anyway.
  • Moderator
  • Moderator
09 Feb 2023 02:08 #264089 by tommylight
Joint mode is any motor/drive/joint is controlled as such, a single motor drive that drives a single linear or angular joint.
Axis are used in World mode, and in LinuxCNC that can be a single motor/drive or up to several motor/drives, that are all controlled as a single axis.
LinuxCNC, can control 9 axis (XYZABCUVW) and each of those can have 1 to 8 motors/drives/joints, if i am not mistaken.
From experience, this has been a magnificent addition to LinuxCNC, as it can be use to square that gantry every time the machine is homed, so even if the machine is not perfectly square or homing sensors are not perfectly aligned, the software can take care of that.
09 Feb 2023 02:25 #264091 by imslo
  • Moderator
  • Moderator
09 Feb 2023 11:04 #264126 by tommylight
Ooops, forgot to mention, the joints/axis with a single drive/motor can be jogged before homing.
So your Z should jog.
If you do need the machine to jog before homing and you do not need squaring the gantry, you can wire two drives on the same output on the Mesa. Also make a new config with only XYZ axis.
Time to create page: 0.254 seconds
