Bridgeport s1 CNC SEM motors and driver cards ok, Anilam Crusader 2 U/S
- Sparky
- Topic Author
3 years 8 months ago #264803
by Sparky
Bridgeport s1 CNC SEM motors and driver cards ok, Anilam Crusader 2 U/S was created by Sparky
My Bridgeport is mechanically ok, currently reworking the head, fitted with Ballscrews as it is CNC. However the crusader 2 is terminal and I wanted to replace it with LinuxCNC. The motors and drive cards are all good (SEM motors with tacho feedback) the driver cards use
+ and - 12 V for speed and direction control.
all axis, z included are fitted with Anilam linear encoders and travel limit switches.
so, to my question, what do I need to purchase to get up and running with Linux CNC?
thanks
thanks
3 years 8 months ago #264954
Replied by andypugh on topic Bridgeport s1 CNC SEM motors and driver cards ok, Anilam Crusader 2 U/S
There are a umber of options for +/- 10V control (which is likely to be what is actually used)
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Supported_Hardware
If you have a parallel port you could look at pico-systems.com/PPMC.html
Otherwise the main contenders come from Mesa. There are two families of Mesa cards either DB25 or HD50. 5i25 +7i77 is a popular combo but the 5i25 seems to be out of stock. There is stock of 7i77 though
store.mesanet.com/index.php?route=produc...83_87&product_id=120
Which can be interfaced with the 7i92T and cotrolled by ethernet.
store.mesanet.com/index.php?route=produc...83_85&product_id=379
(Check with Mesa if the 7i77 pugs into the 7i92TM or TF variant.)
This is similar to the (out of stock) 7i97 ( store.mesanet.com/index.php?route=produc...83_85&product_id=344 )
My machines all use the HD50 style cards. 5i24 + 7i33 is probably worth a look if you have a PCI port (the PCIe 6i24 is out of stock)
Time to create page: 0.040 seconds
