Lathe G2/G3 arc move path inaccuracy
3 years 8 months ago - 3 years 8 months ago #265074 by agdeutschman
Hello,
I am having difficulty achieving tolerance machining a .750" +/-.005" radius.  My lathe has stepper motors with micro-stepping drives, Mesa FPGA and daughtercard.  I have measured x and z axis ball screw backlash and entered compensation values(both are less than .001").  The lathe has been able to consistently achieve /-.001" tolerances on diameters and Z lengths.
I am using Inventor CAD/CAM to generate g-code with a linuxcnc post processor.  Not using control cutter compensation.  Tooling is VNMG 331, material 316SS with coolant.  Cutting speed is 300fpm and fpt is .005".  Tool origin is tip tangent both x and z.
I verified that the G2 arc move on N66 should produce a .750" radius with a 1/64" tool radius by laying out in CAD.  I am measuring the part radius with an optical comparator that has been calibrated against a radius gauge.My radius measurements have been all over the place from .720" to .740" with the optical comparator(measuring the same radius).
I am wondering if my arc profile is more like a series of line segments and the comparator gives me the best fit radius depending on the points I provide.  Small deviations in point data result in large radius error?
Is there a trajectory planning setting that I haven't set correctly somewhere?  Is +/-.005" tolerance on a radius a reasonable expectation?
Edit: I believe linuxcnc defaults to G64(Blend Without Tolerance Mode) by default.  I will change to G61 and see if the radius dimension is improved.  I did not understand how trajectory planning worked before posting.
If anyone on the forum has ideas that could help me out, I greatly appreciate it.
Thanks!
Last edit: 3 years 8 months ago by agdeutschman. Reason: more knowledge
3 years 8 months ago #265148 by andypugh
Are you confident that the tip radius is 1/64 rather than 0.4mm?
Not that the difference is enough to explain this, looking at the numbers. And even then it would be a second-order error, I think.
LinuxCNC should be able to do as it is told, certainly. Though it would be unusual for a radius to be critical, as they are generally for stress relief, clearance or aesthetics.
3 years 8 months ago - 3 years 8 months ago #265241 by agdeutschman
Thanks for your reply andypugh!
I was not certain of my tool radius.  It has a class M tolerance which I believe is .002-.005".  The insert radius measured .0167" on the optical comparator.  I will lay this out in and see how much .001" makes on the resultant radius.
The part I am making is a qualification test and the radii have a /-.005" tolerance.  The first test piece I submitted was rejected for the radii being out of tolerance .005" and .010" respectively.  All other dimensions were in tolerance.  I want to insure that my second submission passes inspection.  I do not know what measurement method the lab uses to qualify samples.  I suspect CMM but the only method I have is optical comparator.  I agree that normally radius tolerance is not critical.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
3 years 8 months ago - 3 years 8 months ago #265271 by agdeutschman
To test differences in trajectory between G64 and G61(and a sanity check), I took slow motion video of the finish profile and made point clouds that increment roughly 025" in radius.  These are attached.
A best fit radius applied to both sets of data is .734".  With a tool radius of 1/64", the tip tangent radius is well within the tolerance of .750" +/-.005".  I believe the trajectory planner is doing what it is supposed to do and G64/G61 is not my problem.
So...  I am stuck wondering whre the discrepancy between command and result is coming from.  Is it something to do with step resolution and system response?  The method I'm using to measure(2x optical comparators)?  Would tool center line have any bearing on the result?
I suppose I could cheat and increase part radius but would really like to discover root cause and solve.
I am willing to test ideas if anyone has them.
Thanks!
Last edit: 3 years 8 months ago by agdeutschman. Reason: attachment
3 years 8 months ago #265323 by andypugh
Try taking out the backlash comp, see what happens then.
3 years 8 months ago #265575 by agdeutschman
Thanks for your suggestion andypugh.
I took out backlash compensation and my radius still measures .735" consistently with optical comparator.
Time to create page: 0.291 seconds
