Wire EDM Machine Retrofit?
1 year 11 months ago #315398 by Tntmold
Replied by Tntmold on topic Wire EDM Machine Retrofit?
Did you ever finish your retrofit? I have a Sodick that needs the same, I made a spark generator that seems to work so I am now ready to start the machine control part. I would benefit from your experience!
1 year 11 months ago #315399 by tommylight
There are several EDM machines using LinuxCNC on youtube, BaxEDM is one of them who builds and sells complete machines.
For retrofit, check if the existing drives and motors work and what control signal they accept, usually step/dir or analog +-10V.
1 year 11 months ago #315476 by smc.collins
I didn't buy a machine yet, i passed, it had spark issues
1 year 10 months ago #316992 by Tntmold
Is BaxEDM implementation of LinuxCNC publicly available or do you have to buy his spark generator to get it?
1 year 10 months ago #316993 by tommylight
Try asking here as he will get a notification of reply on topic he started
forum.linuxcnc.org/10-advanced-configura...e-feed-range-problem
Or write a comment on youtube, he has a channel with the same name there.
Not both at the same time, use one, wait a day or two then use the other.
Time to create page: 0.396 seconds
