GMOCCAPY spindle rpm issue
3 years 8 months ago #265591 by santiagoe
hi all, I am having an issue trying to use a folinn (fuling) BD600 VFD via RS485 with vfdmod, I copied the configuration given in this  thread  and it helped me to get it going to run the spindle CW, CCW and stopping, but I am having an issue with the set RPM, the spindle I am using is 800Hz 24000 RPM, everytime I execute Linuxcnc, the speed defaults to the maximum 800hz and it can not be modulated using the +- buttons (the bar moves but the speed is the same) and when I send a command like M03 S1000 or S10 the spindle will go to the maximum velocity and the VFD also to 800hz, lastly the feedback_bar and at_speed_led are not working not sure why, I am using 2.8.0 version on a raspberry pi 4.
vfd.hal
loadusr -W vfdmod BD600.ini --debug net spindle-vel-cmd-rpm => vfdmod.spindle.rpm-in net spindle-at-speed <= vfdmod.spindle.at-speed net spindle-cw => vfdmod.control.run-forward net spindle-ccw => vfdmod.control.run-reverse
BD600.ini
[Common] MaxSpeedRPM=24000 MinSpeedRPM=100 AtSpeedThreshold=0.05 [RS485] SlaveAddress=1 SerialDevice=/dev/ttyUSB0 BaudRate=9600 LoopDelay=500 ProtocolDelay=6 IsConnectedDelay=10 ConnectionErrorList=110 ConnectionDelay=500 [Control] Address=0x1000 RunForwardValue=0x0001 RunReverseValue=0x0002 FaultResetValue=0x0007 StopValue=0x0006 [SpindleRpmIn] FunctionCode=0x06 Address=0x3000 Multiplier=100 Divider=1 [SpindleRpmOut] Address=0x3001 Multiplier=1 Divider=100 [freq-running] FunctionCode=0x03 Address=0x3001 PinType=float PinName=freq-running Divider=1 [bus-voltage] FunctionCode=0x03 Address=0x3002 PinType=float PinName=bus-voltage [output-voltage] FunctionCode=0x03 Address=0x3003 PinType=float PinName=output-voltage [output-current] FunctionCode=0x03 Address=0x3004 PinType=float PinName=output-current Divider=100 [output-torque] FunctionCode=0x03 Address=0x3006 PinType=float PinName=output-torque [run-speed] FunctionCode=0x03 Address=0x3007 PinType=float PinName=run-speed [spindle-load-speed] FunctionCode=0x03 Address=0x300F PinType=float PinName=spindle-load-speed [power-on-time] FunctionCode=0x03 Address=0x301A PinType=float PinName=power-on-time [spindle-run-time] FunctionCode=0x03 Address=0x301B PinType=float PinName=spindle-run-time [fault-code] FunctionCode=0x03 Address=0x8000 PinType=float PinName=fault-code
CNC.ini
[EMC] MACHINE = CNC DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = gmoccapy POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 1.000000 MIN_SPINDLE_OVERRIDE = 0.100000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/pi/linuxcnc/nc_files INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 6.000000 MAX_LINEAR_VELOCITY = 25.000000 MIN_LINEAR_VELOCITY = 0.500000 DEFAULT_ANGULAR_VELOCITY = 12.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.666667 EDITOR = gedit GEOMETRY = xyz [HAL] HALUI = halui HALFILE = CNC.hal HALFILE = vfd.hal HALFILE = custom.hal POSTGUI_HALFILE = custom_postgui.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal [SPINDLE_0] P = 0 I = 0 D = 0 FF0 = 1 FF1 = 0 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 2000
CNC.hal
setp   pid.s.Pgain     [SPINDLE_0]P setp   pid.s.Igain     [SPINDLE_0]I setp   pid.s.Dgain     [SPINDLE_0]D setp   pid.s.bias      [SPINDLE_0]BIAS setp   pid.s.FF0       [SPINDLE_0]FF0 setp   pid.s.FF1       [SPINDLE_0]FF1 setp   pid.s.FF2       [SPINDLE_0]FF2 setp   pid.s.deadband  [SPINDLE_0]DEADBAND setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT setp   pid.s.error-previous-target true net spindle-index-enable  <=> pid.s.index-enable net spindle-enable        =>  pid.s.enable net spindle-vel-cmd-rpm     => pid.s.command net spindle-vel-fb-rpm      => pid.s.feedback net spindle-output        <=  pid.s.output # ---setup spindle control signals--- net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs net spindle-vel-cmd-rpm        <=  spindle.0.speed-out net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs net spindle-enable             <=  spindle.0.on net spindle-cw                 <=  spindle.0.forward net spindle-ccw                <=  spindle.0.reverse net spindle-brake              <=  spindle.0.brake net spindle-revs               =>  spindle.0.revs net spindle-at-speed           =>  spindle.0.at-speed net spindle-vel-fb-rps         =>  spindle.0.speed-in net spindle-index-enable      <=>  spindle.0.index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true #****************************** # connect miscellaneous signals #****************************** #  ---HALUI signals--- net axis-select-x  halui.axis.x.select net jog-x-pos      halui.axis.x.plus net jog-x-neg      halui.axis.x.minus net jog-x-analog   halui.axis.x.analog net x-is-homed     halui.joint.0.is-homed net axis-select-y  halui.axis.y.select net jog-y-pos      halui.axis.y.plus net jog-y-neg      halui.axis.y.minus net jog-y-analog   halui.axis.y.analog net y-is-homed     halui.joint.1.is-homed net axis-select-z  halui.axis.z.select net jog-z-pos      halui.axis.z.plus net jog-z-neg      halui.axis.z.minus net jog-z-analog   halui.axis.z.analog net z-is-homed     halui.joint.2.is-homed net jog-selected-pos      halui.axis.selected.plus net jog-selected-neg      halui.axis.selected.minus net spindle-manual-cw     halui.spindle.0.forward net spindle-manual-ccw    halui.spindle.0.reverse net spindle-manual-stop   halui.spindle.0.stop net machine-is-on         halui.machine.is-on net jog-speed             halui.axis.jog-speed net MDI-mode              halui.mode.is-mdi
custom_postgui.hal
net spindle-speed-fb <= gmoccapy.spindle_feedback_bar net spindle-at-speed <= gmoccapy.spindle_at_speed_led
also the VFD is configured with the correct parameters according to the next page in the thread I linked above, thank you in advance for your help.
3 years 8 months ago #265594 by tommylight
3 years 7 months ago #265751 by andypugh
Replied by andypugh on topic GMOCCAPY spindle rpm issue
You have a pid for the spindle, but it seems to be unused, so it isn't that, I don't think.
Possibly the VFD expects a frequency input and you are passing RPM?
I don't know how to start Halshow ("show hal configuration") from Gnoccapy, but if there isn't a way to open it built-in, you can always start it with "halshow" at the command line.
That wll allow you to explore what values are on the various HAL pins, and you can trace the numbers through.
3 years 7 months ago #265777 by RobC
Replied by RobC on topic GMOCCAPY spindle rpm issue
In BD600.ini change your rpm multipliers to 3 and 1 then 1 and 3 instead of 100. If that doesn't behave as expected try 30 instead of 100. My vfd is a 400hz / 24k rpm and my settings are 6 and 1, 1 and 6. When set correctly, the vfd at start up should show the frequency required for your minimum speed set in the ini file. I have my minimum set at 4800 rpm, so a frequency of 80 is where it starts by default.
[SpindleRpmIn]
FunctionCode=0x06
Address=0x3000
Multiplier=3
Divider=1
[SpindleRpmOut]
Address=0x3001
Multiplier=1
Divider=3
3 years 7 months ago #266378 by santiagoe
hi, thank you for your suggestion, for example when I set like this:
[SpindleRpmIn]
FunctionCode=0x06
Address=0x3000
Multiplier=3
Divider=1
[SpindleRpmOut]
Address=0x3001
Multiplier=1
Divider=3
the VFD goes automatically to 24 Hz, which I think would be the maximum for this values, the way I calculated multiplier and divider was that I set the value of both to 1 and saw the value the VFD went up to, in this case it showed 8 Hz on the vfd, then I divided the theoretical max with the current maximum value I am getting so I would get the number I needed, so 800/8, this is why I choose 100 as multiplier, but in my case regardless of the multiplier and divider values, the VFD always goes to the max Hz possible, not to the minimum set as you mention, not sure how to accomplish this, may be you can share your configuration files to see if something is different please.
3 years 6 months ago #270163 by santiagoe
Hello again, I managed to get the right Frequency on the VFD by using this values
[SpindleRpmIn] FunctionCode=0x06 Address=0x3000 Multiplier=400 Divider=2 [SpindleRpmOut] Address=0x3001 Multiplier=2 Divider=400
but I am having an issue with the displayed RPM, in the picture attached you can see that it shows s50 RPM but the spindle is currently at 24000 RPM, I have tried to take look at halshow  but I was not able to figure it out, in the picture you can also see the values of some pins on the halshow, any suggestions would be greatly appreciated, thank you.
Time to create page: 0.081 seconds
