dual YY axis problem
3 years 7 months ago - 3 years 7 months ago #266102 by masawee
dual YY axis problem was created by masawee
Hi, im newbie linuxcnc user, i have cheap chinese paraller port machinehave board one relay pin 17, i build my son first cnc, first time use linux and linuxcnc, my linuxcnc have debian 10 2.8.4-1
problem have i add dual YY motor to step conf wizard, not working, i modified config.ini file
add kinematic XYYZ, joint 4, copy paste Y joint1 to joint2 under Yaxis ,z joint add number 3 have normal.
x,yy, working now normal, but Z not move, and display not come yellow line if move Y axis motor move only, Z axis not move and not draw display yellow line. X move ok and draw line. homing axis show only homing X and Z not show homing all axis. not show Y axis. only X and Z.
unhoming show only unhoming all axis X and Z.
select axis manual display, X home axis ok,  yaxis not work, Z axis ok, at display.
why YY not can homing, why Y axis not show. why Z axis not move, why not can homing Y ?
why probe hall meter not show true/false if test. has added to config wizard probe pin 15, and E stop pin 10. but both hall-meter not show contact.
sorry lot have problem because im totally newbie whit linuxcnc and linux user and not undertand code.
sorry not understand good english. finnish understand
Last edit: 3 years 7 months ago by masawee.
3 years 7 months ago #266128 by Clive S
Replied by Clive S on topic dual YY axis problem
Can you post the hal and ini files from the config folder.
As that will help.
3 years 7 months ago #266379 by masawee
Replied by masawee on topic dual YY axis problem
yes can, or i not know how add files here. i try.
3 years 7 months ago #266391 by wusel0464
Replied by wusel0464 on topic dual YY axis problem
Hello,
A joint is missing in your HAL and the reference runs must be defined in the INI
HOME_SEQUENCE = -2
The minus says there are two joints for one axis, the number the order.
So for example Z=0, X=1, and the two Y=-2.
And one reference switch for each Y.
You can simply look at a suitable simulation and then take over the things that are still missing.
Google translator, as my English is even worse.
Greeting Frank
3 years 7 months ago #266394 by masawee
sorry my english not good what need do ? i understand add somewere home seguense.
but not understand this x example what ? need do ?
and what referense need do ?
sorry i not understand code and linux anythink my first time i instal linuxcnc and try use.
what simulation were ?
if someone have working HAL and INI files send to tread.
why linuxcnc not working double Y axis homing ? not have all Y axis homing buttons, only X and Z, but Z no move.
3 years 7 months ago #266400 by masawee
i not found anywere ,were have HOME SEGUENCE row. WERE have ?
need me add this line WERE ?
joint have same what i found some example how add double Y,
X=joint 0, Y= joint 1 and 2, Z joint 3. #Y motors run both together if bush Y but not whit g code or not if homing axis.Z not move newer.
WHAT reference switch ? i not found ref SW anywere what this is ?
Time to create page: 0.255 seconds
